Go to Post I find it ironic how the game "Recycle Rush" can create so much waste. - bEdhEd [more]
Go Back   Chief Delphi > Competition > Regional Competitions
Unread 02-03-2008, 10:19
BenB's Avatar
BenB BenB is offline
AKA: Ben Bennett
FRC #1114 (Simbotics)
BenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond repute
Slack in the Overpass
For teams who competed at Week 1 regionals, did anyone notice any slack in the overpass. Even better, did anyone measure the exact height in the center of the overpass. Every quarter inch matters for us, so the more acturate of an answer, the better.
Thanks!
2010-present - Team 1114 - Simbotics
2007-2009 -Team 2166 - Bluebotics
Unread 02-03-2008, 10:25
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Slack in the Overpass
Team 25 posted something last Thursday indicating the overpass was an inch or so lower than it should have been, so if you're counting on having 1/4" clearance, you might want to rethink your design!
Unread 02-03-2008, 10:33
Dave Campbell's Avatar
Dave Campbell Dave Campbell is offline
Miami Valley Planning Committee
FRC #0144 (ROCK Robotics)
Dave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant futureDave Campbell has a brilliant future
At MWR this weekend, I was on field reset and repair. I did not see any "slack" in the overpass. It does sag a little bit - though I never got a tape on it to measure, but it is just as the rules and field description spell out. If you read the rules and check the tolerances in the field drawings that is what you'll get at the event. Although there are also several fields rotating between the events, other events might have different observations than mine from MWR.
The FTA's and field managers do a tremendous job to ensure the field set-up and conditions are accurate and maintained and keep them fair for the entire event.
"Great spirits have always encountered violent opposition from mediocre minds." - Albert Einstein
FRC Team #144 Advisor
Unread 02-03-2008, 11:45
DeAnnaC DeAnnaC is offline
FRC #1094 (River City Robots)
DeAnnaC has much to be proud ofDeAnnaC has much to be proud ofDeAnnaC has much to be proud ofDeAnnaC has much to be proud ofDeAnnaC has much to be proud ofDeAnnaC has much to be proud ofDeAnnaC has much to be proud ofDeAnnaC has much to be proud ofDeAnnaC has much to be proud of
At the STL Regional rack itself appeared to sag a bit in the front, it was announced several times that the field was 4 inches longer during qualifying matches than it was in the practice matches on Thursday.
Unread 02-03-2008, 11:52
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Yes at the drivers stations the carpet was bunching up because of the robots hitting the wall with such force that it moved the station and stretched the carpet on the playing field.
Unread 02-03-2008, 11:57
Wayne C.'s Avatar Unsung FIRST Hero
Wayne C. Wayne C. is offline
hey- I think we did pretty good?
FRC #0025 (Raider Robotix)
Wayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond repute
"Team 25 posted something last Thursday indicating the overpass was an inch or so lower than it should have been, so if you're counting on having 1/4" clearance, you might want to rethink your design!'
good advice but the design stage was last January and it may be too late......
More on sagging overpass-
By the time NJ was finished yesterday the overpass was visibly torsioned. Numerous robots would hang up on it and try to pull away when they were hurdling and I am sure that was messing up the metal.
Our measurement in the field on Friday night had the overpass by the control side at 76" height midfield and 76.5 right at the wall (atop the wall support). Neither was the 78" assumed height (+- 1 inch). Yesterday it was getting lower in spots to the degree that we would pass cleanly under one side and tip the other on our IR guided round. Our robot height was set for 75". I measured it personally with a tape before the round.
In one round we popped the ball up slightly and it rolled down the overpass in slow motion like the marble in one of those games with the holes. It was obvious that the materials of the overpass were getting beat up and the height was nowhere near 78" as per specs.
As stated previously- we had more issues with the field related nonsense than with dealings with the other robots.
I would like to see teams allowed onto the field at the beginning or the rounds and at downtimes to take measurements so they can adjust their machines(in the same manner we had camera calibration times in prior years). We designed to the specs in the manual. If the field can't maintain that there is a problem.
WC
And one other thing-
we built our bumpers to the exact specs in the manual. We only covered 3 of 4 sides of the robot. Why would they weigh 16.5 lbs? The only way anyone's bumpers seemed to be passing inspection and making weight was to remove the angle aluminum that the manual tells us to put on them. We did so and had a half pound to spare.
If we had 4 bumpers and built them exactly as the manual prescribes they would never be able to pass the weight test. Maybe our experts who write the manual should reexamine their weights and measures or give a more realistic range.
you want that robot to do what?
Raider Robotix- www.raiderrobotix.org
Unread 02-03-2008, 12:10
MrForbes's Avatar
AKA: Jim
Yes, it's too late to start over, but not too late to make some minor changes that might allow for the field elements to be as they really are. I guess that's just one more game challenge...trying to second guess how the actual field will compare to the drawings.
I think our 4 bumpers weighed right around 12 lbs, 26" for the ends and 36" for the sides, 5" high, no angles. Quick calculation of the weight of angle shows that adding 1/16" thick 3/4" angle would put them just over 15 lbs. Perhaps they had 1/2" angle in mind? Not much room for screws then....yes, the prescribed design seems to be questionable.
IndySam's Avatar
Our bumpers are built to spec and cover three sides of our robot, they weigh exactly 10lbs. We have used full bumpers the last two years and have never been anywhere near the max bumper weight.
What size aluminum are you guys using? What size bolts? What kind of plywood?
We use 1/2" and there is plenty of room for the screws.
Unread 02-03-2008, 12:30
President, VEX Robotics, Inc.
Wayne,
Were you measuring to the top of the overpass or the bottom? The specs clearly state the height of 78" is to the top of the overpass. With the pipe at approximately 1.25", the bottom should measure nominal 76.75". With the +/- 1" that would make the range 75.75" to 77.75".
Paul
Unread 02-03-2008, 12:38
Bruce Newendorp Bruce Newendorp is offline
Engineer
FRC #0525 (Swartdogs)
Bruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to beholdBruce Newendorp is a splendid one to behold
We measured the Saint Louis Regional overpass height first thing Thursday since we needed to be pretty close to knock the ball off in hybrid. It was 76" to the bottom of the overpass tubing.
Unread 02-03-2008, 12:49
Jeremiah Johnson's Avatar
Jeremiah Johnson Jeremiah Johnson is offline
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Jeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond repute
Send a message via AIM to Jeremiah Johnson Send a message via MSN to Jeremiah Johnson
Looking at the MWR field I definitely saw some sagging, but nothing that was getting in the teams' way.
Do The Tyler!
XBOX Live Gamertag = theVelvetLie
Unread 02-03-2008, 12:56
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
If the crossover drops two inches, you are going to hear a very loud crash when we go around. Luckily we can easily adjust our height, however, do both sides of the overpass drop the same amount? We will be fine if the crossover is held to +/- an inch, much more than that could cause trouble. We designed according to the specifications, if it looks like it ends up having more of a +/- 1.5 inches for a three inch range from one side to the other, that may cause problems for us and I am guessing several other teams. We would be fine if each side is kept within an inch or two of eachother to even +/- six or seven inches of the stated 78 inch height. How many flags are hitting the overpass? Will we be able to measure the overpass or could the field administration take measurements several times during the day and annouce/post the actual high and low points to the bottom of the tubing for clearance?
Unread 02-03-2008, 17:54
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer & Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
Thanks!
There isn't a noticeable amount of slack. I would advise that when you get to the regional to just double check the hieghts b/c each regional puts together their field differently and so some specs mite be off an acceptable "hair".
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
Unread 02-03-2008, 18:13
Raul's Avatar Unsung FIRST Hero
Raul Raul is offline
Somewhat Useful Person
no team (Formerly - Wildstang)
Raul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond repute
Well, you must have missed seeing us get hung up half the time we went under the middle of the overpass.
Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking.
Unread 02-03-2008, 18:32
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
"And one other thing-
We ran into the same problem. we switched from a 1/8" thick angle to a 1/16" and we lost the weight
the overpass latonya General Forum 3 07-02-2008 20:14
Hurdling using the overpass robogeek753 Rules/Strategy 40 20-01-2008 17:02
How to get the ball over the overpass!? ar2 General Forum 63 11-01-2008 23:58
Carrying the ball under the overpass but across the finish line BaldGuy Rules/Strategy 13 09-01-2008 14:53
Its time for this generation to pick up the slack! KenWittlief Chit-Chat 23 10-02-2006 07:20
