Go to Post The gearbox can be anything, just as long as it weighs less than 0 lbs, and yes, I'm talking about negative weight here. - NoodleKnight [more]
Go Back   Chief Delphi > Technical > CAD
Unread 03-03-2008, 07:29
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Need OverDrive field in 3DS format
Folks,
A friend and I are doing some 3D modeling work and we need a 3D Studio Max 3dS formatted model of the OverDrive field. We intend to import it into our work by using Blender. If you have a model in that format or can convert yours into that format for us; we would love to use it.
Our deadline is very close and we will need the model in the next couple of days, to be able to use it to replace what we have been using. I'm hoping that someone out there already has a decent model "sitting on the shelf".
Please contact me through PMs, by direct email, or by posting here.
Thanks,
Blake
Unread 03-03-2008, 18:35
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Re: Need OverDrive field in 3DS format
I believe that if you use search, you will find a Inventor file. If I recall correctly, you can simply import Inventor into 3ds max.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 05-03-2008, 21:52
gblake's Avatar
AKA: Blake Ross
no team (6th Gear)
Yes; but I need the output of that process, not the input. I am hoping someone who already has Inventor installed... will be able to supply the file.
I did invest considerable time diligently searching for a reference to a model already in 3DS format but I came up empty.
If I had plenty of time I would go through the steps you kindly described; but I simply don't have that much time (because of everything else that needs to be done). The deadline is late tomorrow.
Blake
FIRST Overdrive field in Inventor pmax Inventor 20 05-02-2008 20:02
2008 overdrive playing field dantheflipman General Forum 9 05-01-2008 14:09
Need Intel Logo in EPS or AI format activemx Computer Graphics 3 04-03-2003 17:34
Let's think about a different format of the field archiver 2000 1 23-06-2002 23:52
Autodesk Inventor -> 3ds Max (File Format) Adrian Wong Inventor 1 22-01-2002 23:06
