Go to Post Might change next year. Read the manual then too. - Billfred [more]
Unread 18-02-2008, 23:03
Guarana Guarana is offline
FRC #1706
Guarana is an unknown quantity at this point
gyro problem
I have the gyro on the analog input 01. i am using kevin's code with the gyro and adc enabled. i am getting a reading in the printf for both the rate and the angle. coding it is the trouble.
i am using mecanum programming i found from alan. it works very well on its own.
function:	deadband()
inputs:	inp, input value
		center, value of input that represents neutral
		band, size of deadband to consider neutral
output:	scaled and deadband-compensated output value
		inputs below center will yield negative output
		inputs above center will yield positive output
		inputs within deadband either side of center will yield 0
usage:	typically call with joystick value (0-254) as input,
		joystick neutral (127) as center, and a small number (5)
		as the size of the deadband.  The white POS joysticks
		should probably have a much larger band (10) instead.
int deadband(int inp, int center, int band)
int oup;
	if (inp < center-band)
		oup = inp - center + band;
	if (center-band <= inp && inp <= center+band)
		oup = 0;
	if (center+band < inp)
		oup = inp - center - band;
	return oup;
function:	pwm_limit()
output:	scaled and range-limited output value
usage:	call with signed value (+/- 127) as input,
		will return a valid pwm value
unsigned char pwm_limit (signed int inp)
	if(inp<-127)
		inp = -127;
	if (inp>127)
		inp = 127;
	inp = inp+127;
	return (char)inp;
void Teleop(void)
	l_y = deadband(p1_y,127,10);
	r_y = deadband(p2_y,127,10);
	l_x = deadband(p1_x,127,10);
	r_x = deadband(p2_x,127,10);
	l_y = l_y/2;
	r_y = r_y/2;
	l_x = l_x/2;
	r_x = r_x/2;
	speed = l_y+r_y;
	turn = l_y-r_y;
	slide = -l_x-r_x;
	if(temp_gyro_angle <= -75) //gyro
		turn = turn+15;
	if(temp_gyro_angle >= 75)
		turn = turn-15;
  	front_r = speed-turn+slide;
	front_l = speed+turn-slide;
	back_r = speed-turn-slide;
	back_l = speed+turn+slide;
	pwm01 = pwm_limit(front_r);
	pwm02 = 255 - pwm_limit(front_l);
	pwm03 = pwm_limit(back_r);
	pwm04 = 255 - pwm_limit(back_l);
The commented out part is mine. It is simple and looks like it should work, but whenever the gyro is plugged in, the victors 'flicker'. the orange lights flash very quick, and the wheels get a quick power burst to it, over and over. when the gyro is unplugged, its fine.
suggestions?
Unread 22-02-2008, 08:43
gnormhurst's Avatar
gnormhurst gnormhurst is offline
Norm Hurst
AKA: gnorm
#0381 (The Tornadoes)
gnormhurst will become famous soon enoughgnormhurst will become famous soon enough
Re: gyro problem
Print out the pwm values to see if they correspond to what you are seeing or not. If so, your code is causing the pwm values to do weird things; if the pwm values are steady but the motors are doing weird things, that might point to a wiring problem.
Put printf's inside your conditionals (if(temp_gyro_angle <= -75)...) to see what is going on.
You are increasing/decreasing 'turn' based on gyro. What type is turn? char? int? Is it static?
If turn is a static char and you are increasing it by 15 38 times per second, it will overflow more than 2 times each second (15*38/256).
Trenton Tornadoes 381
2004 Philadelphia Regional Winners
2006 Xerox Creativity Award
My corner of the USPTO.
My favorite error message from gcc: main is usually a function
My favorite error message from Windows: There is not enough disk space available to delete this file.
Unread 22-02-2008, 13:42
Chipawa's Avatar
Chipawa Chipawa is offline
AKA: Mr. Tucker, AKA Chip
FRC #1111 (Powerhawks)
Chipawa is an unknown quantity at this point
Re: gyro problem
This may be a shot in the dark .... but try plugging the gyro into analog input 02. This fixed a problem we experienced with the gyro.
2010 DC Engineering Innovation Award
2010 DC Spirit Award
2008 Chesapeake Finalist
2008 Chesapeake Rockwell Automation Innovation in Controls award
Unread 23-02-2008, 21:16
FRC #1706
Re: gyro problem
thanks for the help. i wont really be able to check it until thursday at competition, so i want to make sure this is right.
turn is declared as a signed int. will this have the same affect? how would i go about fixing that? this gyro is completly new to me.
Unread 23-02-2008, 23:38
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
Re: gyro problem
try using a feedback loop...a simple one would look like:
turn = turn - temp_gyro_angle / 15;
or something like that. this will get you (theoretically) a robot that always points forward. you may want to make the ratio that you multiply temp_gyro_angle by higher or lower depending on how fast/slow you want it to correct.
also, gnormhurst, he couldn't be overflowing because turn is set every step...
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 24-02-2008, 02:56
FRC #1706
Re: gyro problem
you mean divide by? and yes i get what you mean. but again, i won't be able to test until competition.
Unread 24-02-2008, 12:04
Uberbots's Avatar
Mad Programmer
AKA: Billy Sisson
Re: gyro problem
well you are multiplying by 1/15, so i mean multiply.
RPI 2012
BREAKAWAY
Unread 24-02-2008, 17:06
cgront's Avatar
cgront cgront is offline
None #0159
Team Role: Operator
cgront is an unknown quantity at this point
Re: gyro problem
I think that you should use Get_Gyro_Angle() to get data from the gyro. That is how we used it. Also We had a similar problem with our field centric omni drive. It was caused by a division by 0. Good Luck from 1647
some of Murphy's Laws of Computing
1)When computing, whatever happens, behave as though you meant it to happen.
Unread 24-02-2008, 22:52
FRC #1706
Re: gyro problem
	signed int speed, turn, slide;
	signed int front_r, front_l, back_r, back_l;
	long int l_y, r_y, l_x, r_x;
	static unsigned int i = 0;
	static unsigned int j = 0;
	int temp_gyro_rate;
	long temp_gyro_angle;
	int temp_gyro_bias;
	long temp_gyro_angle_fast;
	long Encoder_Count;
	i++;
	j++; // this will rollover every ~1000 seconds
	// enable this block of code to test your gyro
	if(j == 10)
		printf("\r\nCalculating Gyro Bias...\r\n");
	if(j == 38) // let the gyro stablize for a second before starting a calibration
		// start a gyro bias calculation
		Start_Gyro_Bias_Calc();
	if(j == 191) // allow calibration routine to run for four seconds
		// terminate the gyro bias calculation
		Stop_Gyro_Bias_Calc();
		// reset the gyro heading angle
		Reset_Gyro_Angle();
		temp_gyro_bias = Get_Gyro_Bias();
		printf("Gyro Bias=%d\r\n", temp_gyro_bias);
	if(i == 35 && j >= 191)
		temp_gyro_rate = Get_Gyro_Rate();
		temp_gyro_angle = Get_Gyro_Angle();
		printf("Gyro Rate=%d\r\n", temp_gyro_rate);
		printf("Gyro Angle=%d\r\n\r\n", (int)temp_gyro_angle);
Here is the gyro calibration code. Is there anything wrong with this? Something I noticed, is that i and j both add one for each loop. So how does i = 35 and j be higher than 191 if they are always the same (for the last section). maybe i am missing something. would that be any reason?
Unread 03-03-2008, 15:48
Ken Streeter's Avatar
Ken Streeter Ken Streeter is offline
Let the MAYHEM begin!
FRC #1519 (Mechanical Mayhem)
Ken Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond repute
Re: gyro problem
	int temp_gyro_rate;
	int temp_gyro_bias;
	long Encoder_Count;
	i++;
	if(j == 10)
		Reset_Gyro_Angle();
Further down in the code, i is reset to 0 every time that it increases to 38, in a small block as follows:
	// reset the loop counter
	if(i >= 38)
		i = 0;
Essentially, i is the number of loops in the "current second" of looping; while j is the total number of loops executed in teleop since the robot was reset.
Ken Streeter - Team 1519 - Mechanical Mayhem (Milford Area Youth Homeschoolers Enriching Minds)
2015 NE District Winners with 195 & 2067, 125 & 1786, 230 & 4908, and 95 & 1307
2013 World Finalists & Archimedes Division Winners with 33 & 469
2013 & 2012 North Carolina Regional Winners with teams 435 & 4828 and 1311 & 2642
2011, 2010, 2006 Granite State Regional Winners with teams 175 & 176, 1073 & 1058, and 1276 & 133
Team 1519 Video Gallery - including Chairman's Video, and the infamous "Speed Racer!"
Problem with gyro... capenga Programming 21 16-02-2006 19:25
Gyro not accurate - Problem naor52 Programming 15 27-01-2006 16:50
Gyro code problem AMIRAM Programming 10 23-01-2006 04:26
Gyro magical hands Programming 2 14-01-2005 20:57
