Go to Post However, in the end, the renderer is only as good as the artist. - MiNT [more]
Unread 20-02-2008, 22:39
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
pic: The 2008 Team 703 Phoenix Robot
Unread 20-02-2008, 22:41
cbale2000's Avatar
AKA: Chris Bale
Re: pic: The 2008 Team 703 Phoenix Robot
Some random facts about the robot this year:
* 10 wheel drive
* 2 speed transmission
* Use of composites in several places
* Relatively Low CoG
* Very hard to tip
* Faster than last years
* Looks a bit like one of our other robots (you guess which one)
* The lift is DEAD silent (Not really a useful quality, but cool nonetheless)
* The drive system handles like a dream (very smooth)
I'd also like to note that the wood part is temporary, the part will be replaced with a carbon fiber version.
2005-2008: FRC 703 Phoenix - Driver
2009-2016: FRC 703 Phoenix - Mentor
2017-????: FRC 5712 Gray Matter - Mentor
Unread 20-02-2008, 22:44
XaulZan11's Avatar
XaulZan11 XaulZan11 is online now
AKA: John Christiansen
XaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond repute
Send a message via AIM to XaulZan11
Only 10 wheels...I'm a little diapointed
Looks good and good luck!
Unread 20-02-2008, 22:50
cbale2000's Avatar
AKA: Chris Bale
Yeah, we figured the 14 wheels last year was a bit... overkill for this game. The nice thing about this drive is that it is a lot lighter and more efficient with chains instead of gears.
Last year the entire drive was powered from the back of the bot, this year we centered everything and connected the center wheel directly to the gearbox using a hex shaft. The nice thing about the hex shaft is even if we should break every chain on the robot, we will still have 2 wheels working.
Unread 20-02-2008, 23:49
Vince lau's Avatar
Vince lau Vince lau is offline
Building robots since 1995
FRC #4914
Vince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond repute
Send a message via MSN to Vince lau
nice robot, can't wait to see it in action at GTR
2005 - GTR WFFA
2006 - Waterloo Regional Champions with 1114 and 1503
2010 - Waterloo Rookie inspiration and Highest Rookie Seed, #2 Alliance Captain, Semi-finalists.
2011 - Waterloo Finalist thanks 1310 and 610
2014 - imagery and rookie allstar award gtr west
2014 - rookie inspiration and winners with 188 and 610 north bay
Unread 21-02-2008, 08:28
GaryVoshol's Avatar
Cogito ergo arbitro
My first reaction too. But I was consoled by the fact that you're using carbon fiber.
As far as picking up the ball, I have this guess. Those two side-board mounted cylinders will pull your entire tower forward on an angle. This will allow the yet-to-be-replaced wood cradle to "kneel" in front of the bumper, and the wheel at the top will scoop the Trackball in. Am I close?
Looking forward to seeing this in competition.
(since 2004)
Unread 21-02-2008, 09:33
Mike Harrison's Avatar
Mike Harrison Mike Harrison is offline
Don't Mess with Leila
AKA: The Foof
FRC #0217 (ThunderChickens)
Team Role: Operator
Mike Harrison has much to be proud ofMike Harrison has much to be proud ofMike Harrison has much to be proud ofMike Harrison has much to be proud ofMike Harrison has much to be proud ofMike Harrison has much to be proud ofMike Harrison has much to be proud ofMike Harrison has much to be proud ofMike Harrison has much to be proud of
are the two wheels in the back not directly driven? i see no chain.
Unread 21-02-2008, 09:42
TD78 TD78 is offline
AKA: Tom Dolan
FRC #0078 (AIR Strike)
TD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant future
My guess is that the chain is on the inside of the wheels. Same with the two-wheeled section in the middle.
FRC78: 2010-Present
FRC121: 2002-2009
Unread 21-02-2008, 13:39
diesel's Avatar
diesel diesel is offline
FRC #2077
diesel has a spectacular aura aboutdiesel has a spectacular aura about
I count 11 wheels
Design. Build. Dew.
Unread 21-02-2008, 21:15
cbale2000's Avatar
AKA: Chris Bale
Very, very close, the only thing different is that the cradle actually doesn't go in front of the bumpers, it will rest either slightly on top or behind them. But you basically got it right.
Yes, that is correct, the wheel chains alternate sides.
Originally Posted by diesel View Post
I count 11 wheels
Well, if you want to get technical...
Unread 22-02-2008, 01:46
zander_108's Avatar
zander_108 zander_108 is offline
AKA: Zander Guerra
FRC #0108 (Sigmac@t)
zander_108 will become famous soon enoughzander_108 will become famous soon enough
Send a message via ICQ to zander_108 Send a message via AIM to zander_108
i have a guess how it grabs the ball
those two pneumatic pistons lean the entire manipulator assembly down, so the wheel can roll the ball up into its cradle.
Unread 22-02-2008, 08:49
PDF32100 PDF32100 is offline
AKA: Pedro
FRC #0714 (SUPER PANTHERS)
Team Role: Driver
PDF32100 has a spectacular aura aboutPDF32100 has a spectacular aura aboutPDF32100 has a spectacular aura about
Send a message via AIM to PDF32100 Send a message via MSN to PDF32100
i doubt its finished but if it isss
DONT FORGET THE BUMPERS
Unread 22-02-2008, 15:42
cbale2000's Avatar
AKA: Chris Bale
Yeah we know. We figured "Lexan side plates + No bumpers = Bad", anyways so we'll have them on one way or another.
Unread 22-02-2008, 15:58
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
nice looking bot guys looks nice a strong!! See you at GTR!
Unread 03-03-2008, 19:20
703Trombley703's Avatar
703Trombley703 703Trombley703 is offline
FRC #0703 (Pheonix)
703Trombley703 is an unknown quantity at this point
Send a message via AIM to 703Trombley703
OMG!!! I can not wait to see this baby in action at Detroit!!!
Oh yeah can't forget about that good ol carbon fiber. haha
pic: Team 191 the X-Cats 2008 robot Xtender Koko Ed Robot Showcase 2 22-02-2008 01:00
pic: The 2007 Team 703 Phoenix Robot cbale2000 Extra Discussion 16 05-04-2007 14:17
pic: Team Phoenix - 703 at Buckeye MattB703 Extra Discussion 1 03-04-2006 15:57
pic: Team 703 Phoenix POLISH703 Robot Showcase 6 07-03-2005 12:39
pic: Phoenix 703 "almost done" MattB703 Robot Showcase 13 16-02-2005 14:34
