Go to Post Coming from one of the biggest mecanum fanboys in FIRST- have fun, drive fast, and forget the haters. - Brandon Zalinsky [more]
Unread 04-03-2008, 01:27
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
Success with IR remotes in Week #1?
Just wondering how many teams used IR remotes last week and how successful they were with commanding their robots.
Over what range did the remote operate reliably?
Was there interference (jamming) from other IR remotes?
Did you position your Robocoach on the far side of the field?
Please describe your experience and what you plan to do to improve reliability.
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Unread 04-03-2008, 02:05
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: Success with IR remotes in Week #1?
We use IR to tell our robot where our trackball is. The robot then follows a predetermined trajectory.
IR worked well for us and we experienced no interference, even when partnered with other teams also using IR.
We lost the ability to control the robot using IR about 15' away from the player station, I'd guess. We have an abort function that did not work during competition, but worked fine in our lab. Our robocoach was positioned next to our player's station.
We experienced a power failure mid-match during the elimination rounds that, it seems, wiped out the IR board's learned signals. After that round, our IR remote was unable to signal the robot and our hybrid mode no longer worked. Ultimately, we were eliminated as a result. (Sorry 100 and 2550. Really.)
--Madison--
...down at the Ozdust!
Unread 04-03-2008, 02:13
dtengineering's Avatar
AKA: Jason Brett
Our IR remote worked GREAT! For changing TV channels, at least.
If you wanted it to work on the robot you needed something other than the IR board. Although IR board reprogramming was availble on Thursday at Oregon, our board cut out at some point between the end of re-programming and the beginning of competition.
It probably wouldn't have made much difference. A simple "drive forward" command was enough to pick up four points, and a simple timed loop almost got us around the corner on the first try.
Our most effective use of auto mode was in the quarters when (after getting blown out in the first match by two really good auto-bots) we just moved forward about four feet using a timed loop and blocked their path. Hardly brilliant, but it was effective. We should have finished off with a quick sprint across the four point line, now that I think of it.
But hybrid mode has possibilities, and I think it should be not too difficult to completely bypass the IR board and hook a Vishay or PNA4602M style receiver up to the RC and read the IR transmissions directly. We've been doing it for years with PIC 16f627 and 16f84 chips on mini-sumo robots that we build, but we use PIC Basic Pro, which has some very efficient commands for doing that kind of stuff and only use the Sony IR protocol. We'll need to put together some good C programmers to come up with a reliable and simple way of doing it on the RC.
Jason
Unread 04-03-2008, 02:15
Guy Davidson Guy Davidson is offline
AKA: formerly sumadin
FRC #0008 (Paly Robotics)
Guy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to behold
Send a message via ICQ to Guy Davidson Send a message via AIM to Guy Davidson Send a message via MSN to Guy Davidson
We never used our remote, although we are planning to for the next regional.
Other than the cutting out issue, do you feel the problems were mostly with the specific IR board itself, or with using IR communication (due to noise or line-of-sight issues)?
Unread 04-03-2008, 03:02
Cow Bell Solo's Avatar
Cow Bell Solo Cow Bell Solo is offline
No Stolte No
AKA: Chris
FRC #2194 (Fondy Fire)
Cow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the rough
Send a message via AIM to Cow Bell Solo Send a message via MSN to Cow Bell Solo Send a message via Yahoo to Cow Bell Solo
that is good to know about the IR remote, I might have a backup code ready for competition
Who let the Blue Smoke Out
Team 2194 Mentor - 2012-Present - http://fondyfire.com
Team 2207 Alumni - http://whitebearlakerobotics.com
Iowa FIRST LEGO League Planning Team Member - 2010-Present - http://www.isek.iastate.edu/fll
FIRST LEGO League volunteer - 2008-Present
2008: MN Regional Quarterfinalists, Website Excellence
2009: MN North Star Quarterfinalists, recognized for safety, Website Excellence
Unread 04-03-2008, 03:06
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Originally Posted by dtengineering View Post
...I think it should be not too difficult to completely bypass the IR board and hook a Vishay...style receiver up to the RC and read the IR transmissions directly. We've been doing it for years with PIC 16f627 and 16f84 chips on mini-sumo robots that we build, but we use PIC Basic Pro, which has some very efficient commands for doing that kind of stuff and only use the Sony IR protocol. We'll need to put together some good C programmers to come up with a reliable and simple way of doing it on the RC.
This should make the task a bit easier:
http://www.chiefdelphi.com/forums/sh...ad.php?t=65065
-Kevin
Kevin Watson
http://kevin.org
IR REMOTES team550 Control System 2 15-01-2008 00:00
High Output IR LEDS in Remotes 7-11number1 Electrical 4 13-01-2008 17:38
Toltechs success with camera Andrew Schuetze Robot Showcase 9 17-02-2007 23:20
any success with winches? Ben.V.293 Technical Discussion 15 28-01-2004 22:38
Success with Tank Treads Yan Wang Technical Discussion 17 23-01-2004 15:53
