Go to Post STICK WITH WHAT WORKS FOR YOU!!! - Will Hanashiro [more]
Unread 04-03-2008, 10:51
Re: 1519 - One Dual-Config Robot or Two Robots?
Originally Posted by squirrel View Post
...Unbolt the arm, bolt on the ramp, you've completely changed your game plan, but still have the same robot under it all. 1519 has to replace the whole robot to change game plans.
I still don't see anything in the rules to justify how you're using the word "robot". You obviously have your own idea of what a "robot" is, independent of what the rules say (or fail to say).
Would you accept a team that designed a robot with a replaceable drivebase? Unbolt the tank drive module and bolt on the Mecanum drive module. Your comment about "same robot under it all" would seem to reject this as a valid option, but there's nothing in the rules making it illegal so far as I can tell.
pic: 1519 robot as of last tuesday dbell Extra Discussion 33 17-02-2008 19:09
pic: 1519 Robot Done (in LEGO CAD that is...) Tapoore Extra Discussion 12 13-01-2008 00:56
Dual Robots ChrisMcK2186 Rules/Strategy 15 08-01-2008 15:42
[ECDU]:one or two Michael Leicht FIRST-related Organizations 16 09-12-2004 07:23
two robots utishpenguin Rumor Mill 26 03-10-2002 02:57
