Go to Post You are not limited by your resources, but by your imagination. - John Gutmann [more]
Go Back   Chief Delphi > Other > VEX
Unread 04-03-2008, 19:12
ben_0614 ben_0614 is offline
FRC #0228 (GUS)
Team Role: Operator
ben_0614 has a spectacular aura aboutben_0614 has a spectacular aura about
VEX problem...
Hey everyone, I'm a little puzzled...
I'm having a slight issue with programming my Vex r/c. I can't get the motors to run under r/c control. I don't get it. Everything is plugged in, crystals match, motors plugged into the right port, etc. I can get motor ports 2 and 3 to run under the default code. I also can get it to run under online code. Making the motors run with a pwm value also works. I just can't figure out why the r/c control isn't working.
Some help please.
Thanks, Ben.
Oh, btw, it's to run a 4 speed transmission...
Unread 04-03-2008, 19:16
Joe G.'s Avatar
Joe G. Joe G. is online now
AKA: Josepher
no team (Formerly 1687, 5400)
Re: VEX problem...
If you are using easy C 2 for Vex, you probably forgot to put a while==1 loop in the operator control program. This needs to surround the entire program to have it run continuously.
Unread 04-03-2008, 19:33
FRC #0228 (GUS)
Team Role: Operator
Re: VEX problem...
Okay, I got it working. Thanks a lot!
I don't program much, so I'm still learning.
4 speed tranny:
Still need to build the mechanism to slide the shafts. It's extremely complicated and inefficient. I still don't know how it's going to drive either.
Unread 04-03-2008, 19:47
Re: VEX problem...
Are you planning on having a rack/pinion set-up with a central servo?
Unread 04-03-2008, 20:06
FRC #0228 (GUS)
Team Role: Operator
Re: VEX problem...
No, I want them to be independent of each other so that it can have the 4 speeds. I don't have the Advanced Gear kit yet, so I'm just going to have two motors with move them with a little lever or something.
Unread 04-03-2008, 20:36
Rick's Avatar
Rick Rick is offline
Ready to STRIKE!
AKA: Rick Blight
FRC #0078 (AIR STRIKE)
Rick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond reputeRick has a reputation beyond repute
Re: VEX problem...
Is this for his years competition? If so, why would you every need 4 speeds.
Like Aquidneck Island Robotics on Facebook!
Unread 04-03-2008, 22:17
Re: VEX problem...
You don't really need it at all, but it still shows the teams mechanically abilities. It could get the think award if you explain it to the judges well enough. Also, you would have to state the reason of why you did it though.
Unread 05-03-2008, 16:06
FRC #0228 (GUS)
Team Role: Operator
Re: VEX problem...
No, it's my personal robot. Just making it for fun...
Problem using VEX shaft encoder jskene Programming 15 28-10-2007 22:33
2006 WIRED Vex Challenge and Milwaukee Vex League Kevin Kolodziej Off-Season Events 15 04-12-2006 09:59
Vex SquareBot- movement programming problem Nathan VEX 2 05-11-2006 17:19
Vex Announcement: FIRST Vex Challenge Extended for 2006-2007 KathieK FIRST Tech Challenge 14 30-07-2006 23:42
Vex Transmitter problem TheOtherGuy FIRST Tech Challenge 3 21-07-2006 17:01
