Re: The Magical IR Board
Billy,
That kind of damage tells me there is something else wrong. I would first look for a shorted regulator and/or the possibility of a short to chassis in the mounting. If you find the chassis short, that indicates another part of the robot is also contacting the chasis and passing current throught the frame and through the little trace on the IR board. When you replace the fuse (board trace) with a bigger fuse (the wire) something else will have to give. Let us know what you find. |
we havent had a problem since then. I will post again if something comes up, and the new record for most burnouts survived (= |
sorry to ruin the spirit but it did not have nine lives, but it is a good story anyways and has a good moral, don't give up(that is what I took)
Billy,
I am glad you found the real problem. I fix things for a living and I use the "smoking gun" approach. If you don't find the real cause of a problem, it isn't fixed. It is just waiting for the best time to come out and bite you. Good luck! |
Wow you guys got lucky...
We just turned are board on one time at Midwest and it died... |
Brent,
You should have come and asked me. I had the hardware to reprogram if you had wanted to use it. |
| Does the IR board have to go in the crate? | dyanoshak | Sensors | 5 | 19-02-2008 14:56 |
| what is the four pin white connector for on the ir board ? | Smaug | Electrical | 2 | 10-01-2008 23:37 |
| Lights in Joystick board or control board | rcubes85 | Control System | 15 | 26-02-2005 23:40 |
| pic: They're Magical! | Ianworld | Extra Discussion | 2 | 30-01-2005 17:24 |
| Perf Board = BS2-IC Carrier Board? | indieFan | Electrical | 2 | 16-09-2004 08:28 |
