Go to Post If everyone else in the world is an idiot, you may need to recalibrate your idiotness scale. - GaryVoshol [more]
Unread 04-03-2008, 22:51
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
The Magical IR Board
In light of all of the... bad things that are happening to some of the IR boards that i see here on CD, i think it is time to post the story of the IR board with 9 lives.
Ok, so this story starts out with a short circuit. A bad one at that. We had built a custom IR receiver panel with 8 receivers built into it, and two of them shorted together. So the IR signals stop being processed- and with good reason. We look at the IR board and it is smoking- we let the genie out of the copper trace leading to the output pins where the IR sensor is (was). looking at the trace, it was destroyed. there was a hole burned right in the middle of it, and i was convinced that the board was dead, and so we started to prepare the second board.
But then, my dad got a wonderful idea. He soldered a small copper wire clipping over the gap. We turned on the board and, lo and behold, it returned to life as if nothing had happened. It responded to input and everything. So we put it back on the bot, and proceed to test another hybrid mode. As the robot is making its high-speed turn, we start to notice MORE smoke pouring out of the IR board. So we run over, take a look, and now the ENTIRE trace that was leading to the IR sensor was gone, charred up, and fallen on the floor somewhere.
But my dad was persistent- we had the technology to make this board come back again. so we solder a longer peice of copper wire to the two ends of the trace, turn the board on, and IT WORKS!
AGAIN!
so this is a story of the IR board with 9 lives. I guess what we have learned, contrary to the experiences of other teams, is that these little guys are very hardy, and that a short in that place is fixable.
=D
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 04-03-2008, 23:17
Re: The Magical IR Board
Billy,
That kind of damage tells me there is something else wrong. I would first look for a shorted regulator and/or the possibility of a short to chassis in the mounting. If you find the chassis short, that indicates another part of the robot is also contacting the chasis and passing current throught the frame and through the little trace on the IR board. When you replace the fuse (board trace) with a bigger fuse (the wire) something else will have to give. Let us know what you find.
Unread 04-03-2008, 23:46
Uberbots's Avatar
Mad Programmer
AKA: Billy Sisson
Billy,
No, it was an intermittent short in the custom sensor board. my dad trimmed all of the elongated pins coming out of the sensors, and then cased them all in hot glue.
we havent had a problem since then. I will post again if something comes up, and the new record for most burnouts survived (=
RPI 2012
BREAKAWAY
Unread 05-03-2008, 00:17
Cow Bell Solo's Avatar
Cow Bell Solo Cow Bell Solo is offline
No Stolte No
AKA: Chris
FRC #2194 (Fondy Fire)
Cow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the rough
Send a message via AIM to Cow Bell Solo Send a message via MSN to Cow Bell Solo Send a message via Yahoo to Cow Bell Solo
sorry to ruin the spirit but it did not have nine lives, but it is a good story anyways and has a good moral, don't give up(that is what I took)
Who let the Blue Smoke Out
Team 2194 Mentor - 2012-Present - http://fondyfire.com
Team 2207 Alumni - http://whitebearlakerobotics.com
Iowa FIRST LEGO League Planning Team Member - 2010-Present - http://www.isek.iastate.edu/fll
FIRST LEGO League volunteer - 2008-Present
2008: MN Regional Quarterfinalists, Website Excellence
2009: MN North Star Quarterfinalists, recognized for safety, Website Excellence
Unread 05-03-2008, 07:22
Billy,
I am glad you found the real problem. I fix things for a living and I use the "smoking gun" approach. If you don't find the real cause of a problem, it isn't fixed. It is just waiting for the best time to come out and bite you. Good luck!
Unread 05-03-2008, 20:55
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
Wow you guys got lucky...
We just turned are board on one time at Midwest and it died...
Unread 06-03-2008, 07:35
Brent,
You should have come and asked me. I had the hardware to reprogram if you had wanted to use it.
Does the IR board have to go in the crate? dyanoshak Sensors 5 19-02-2008 14:56
what is the four pin white connector for on the ir board ? Smaug Electrical 2 10-01-2008 23:37
Lights in Joystick board or control board rcubes85 Control System 15 26-02-2005 23:40
pic: They're Magical! Ianworld Extra Discussion 2 30-01-2005 17:24
Perf Board = BS2-IC Carrier Board? indieFan Electrical 2 16-09-2004 08:28
