Re: Help with the IR board
RE-5v regulator failures:
If you take pin 2 on the ICSP header and run it to a 5v source on the rc, you can bypass the regulator, and make it work. I'm not sure if its reccomended or not, but in a pinch it works. |
| need help with ir board | shumajax | Electrical | 2 | 04-03-2008 16:19 |
| Figure out what's wrong with the IR board | sparrowkc | Electrical | 5 | 17-02-2008 12:29 |
| HELP!!! STUCK WITH SUB ROUTINES WITH THE IR!!! | drewjones13 | Programming | 1 | 17-01-2008 20:52 |
| Do you have a problem with the IR Board? | DonRotolo | Control System | 5 | 07-01-2008 23:57 |
| Please help me with the size of the rotating light!!! | bigqueue | Technical Discussion | 5 | 21-01-2002 09:40 |
