Go to Post NASA rarely launches another rocket just so the programmers can see if they've fixed a bug. - Greg McKaskle [more]
Unread 04-03-2008, 22:09
dominater35 dominater35 is offline
FRC #0288
dominater35 is an unknown quantity at this point
Help with the IR board
First off let me say that our IR board doesn't work at all. We cannot even get anything to happen when power is applied. So i was wondering where we could get a new one bcuz i've checked everywhere.
Unread 04-03-2008, 22:17
billbo911's Avatar
billbo911 billbo911 is online now
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: Help with the IR board
It could be a couple of different things causing the problem
1) The +5 vdc regulator is shot. Replacing it will fix that issue.
2)The code in the board might be corrupt. There will be people at the regionals that can re-program the board.
There is another option. Kevin Watson has written code that uses a simple VISHAY sensor to entirely replace the IR board. $2 for the sensor, one PWM cable and ten minutes of coding and you should be good to go. This "Sticky" post has all the details.
Unread 05-03-2008, 00:25
Cow Bell Solo's Avatar
Cow Bell Solo Cow Bell Solo is offline
No Stolte No
AKA: Chris
FRC #2194 (Fondy Fire)
Cow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the rough
Send a message via AIM to Cow Bell Solo Send a message via MSN to Cow Bell Solo Send a message via Yahoo to Cow Bell Solo
request one using CD-swap, at your competition request one over the PA if anyteam is willing to give you theres or else create a hybrid without using the IR
Who let the Blue Smoke Out
Team 2194 Mentor - 2012-Present - http://fondyfire.com
Team 2207 Alumni - http://whitebearlakerobotics.com
Iowa FIRST LEGO League Planning Team Member - 2010-Present - http://www.isek.iastate.edu/fll
FIRST LEGO League volunteer - 2008-Present
2008: MN Regional Quarterfinalists, Website Excellence
2009: MN North Star Quarterfinalists, recognized for safety, Website Excellence
Unread 05-03-2008, 00:55
Binome's Avatar
Binome Binome is offline
Programmer/Electronics/CAD
AKA: Patrick
FRC #2273 (SHIM)
Binome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of lightBinome is a glorious beacon of light
RE-5v regulator failures:
If you take pin 2 on the ICSP header and run it to a 5v source on the rc, you can bypass the regulator, and make it work. I'm not sure if its reccomended or not, but in a pinch it works.
Unread 05-03-2008, 14:17
If you checkout the IR schematic in the documents on the First website you will see a note on what to remove and what to add to use an external 5 volt supply.
Unread 05-03-2008, 15:10
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
I wonder why they designed it with a 5V regulator, when they knew we would be connecting to our RC anyway...
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 05-03-2008, 15:20
They give you the option of connecting to a 7.2-12 volt source with regulator or to a 5 volt source without the regulator. Your choice depending on application with the RC (Backup battery) or a custom circuit using a local 5 volt supply. Crafty devils these designers!
need help with ir board shumajax Electrical 2 04-03-2008 16:19
Figure out what's wrong with the IR board sparrowkc Electrical 5 17-02-2008 12:29
HELP!!! STUCK WITH SUB ROUTINES WITH THE IR!!! drewjones13 Programming 1 17-01-2008 20:52
Do you have a problem with the IR Board? DonRotolo Control System 5 07-01-2008 23:57
Please help me with the size of the rotating light!!! bigqueue Technical Discussion 5 21-01-2002 09:40
