Re: Basils needs a robotics team
http://www.firstnemo.org/resources.htm may be a good resource for you. Also, find a team in the area, that would be willing to mentor your team.
You may also want to search the white papers here, I'm not sure but there may be some documents in there to help you. If there isn't might I suggest documenting what you do and publishing a white paper yourself. Good luck in starting your team. |
| NEW TEAM - Pioneer HS Team 1015 in Ann Arbor MI Needs Mentors | kmcclary | General Forum | 17 | 10-04-2012 08:22 |
| New Robotics Lab design needs your input | Peter Randall | Technical Discussion | 21 | 25-02-2007 22:33 |
| Team 61 Needs helps in programming | Mike Norton | Programming | 4 | 20-02-2005 19:02 |
| A Team needs help! | archiver | 1999 | 2 | 23-06-2002 22:57 |
| team 497 needs a part | Andrew Dahl | General Forum | 0 | 25-02-2002 13:22 |
