Go to Post Take care of what's there and you never need a replacement. - Rich Kressly [more]
Unread 05-03-2008, 03:14
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
Linear Shooters - How did you do it?
My team experimented with a Pneumatic Piston Shooter similar to that of Simbotics but we barely got the ball to clear a 20cm (~8") barrier, let alone the overpass from 2-3 meters away....
How did simbotics or any other similar team make it effective?
(Was it even pneumatic?)
<edit>
Just noticed that Simbotics was not pneumatic - but how did it work?
did anyone manage a linear shooter with pneumatics?
</edit>
just curios...
-Leav
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 05-03-2008, 03:23
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
Re: Linear Shooters - How did you do it?
The make a linear pneumatic shooter you must latch down the cylinder. By allowing it to extend 1/2way and then latching it in place your manage to store energy to later by used in firing. Similar actuating the cylinder stores very little energy where you need it and hence doesn't shoot the ball very far.
Note: It is actually better to allow the cylinder to extend about 1/3 of the way then latch it for maximum energy imparted. This can be seen by setting up an integral for the pressure vs volume graph.
Unread 05-03-2008, 05:35
Curt Henderson's Avatar
Curt Henderson Curt Henderson is offline
FRC #1501 (Team T.H.R.U.S.T)
Curt Henderson is a jewel in the roughCurt Henderson is a jewel in the roughCurt Henderson is a jewel in the rough
Send a message via Yahoo to Curt Henderson
Team 1501 took a different approach to the shooter design. We use pnuematic cylinders to pivot a monocoque constructed sail which telescopes out the rails (chrome-moly tubing) to tension surgical that is attached to our sled. A tilting action on the sled is created by the pivoting of the sail which use to pick up the ball for launch. We have posted videos on youtube.com that demonstrates our design. We went in this derection for two reasons, first, as a means to build a safe energy device to eliminate injuries and secondly, it is a cool mechanism that works very effectively.
We also have a unique device to remove the ball from the overpass which we have intensionally kept from display.
Unread 05-03-2008, 05:54
Leav's Avatar
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Very cool robot from 1501: http://www.youtube.com/watch?v=D5OC-Y-af74
just to satisfy my curiosity: are any teams using pneumatic pistons to directly launch the ball?
-Leav
-Paraphrasing JFK
Unread 05-03-2008, 06:42
Dgrez Dgrez is offline
FRC #0612
Team Role: Driver
Dgrez will become famous soon enoughDgrez will become famous soon enough
Team 612 uses two pneumatic pistons to directly launch the ball and it is rather effective. They drop out once the elevator reaches the correct height and fire.
http://youtube.com/watch?v=VbGBxKjMlh0
Unread 05-03-2008, 09:39
dpc131's Avatar
dpc131 dpc131 is offline
AKA: Dan
FRC #0836 (Robobees)
dpc131 is a jewel in the roughdpc131 is a jewel in the roughdpc131 is a jewel in the rough
We have a different approach. We are using two 2" Cylinders to put force into compressing a set of springs. We then latch the springs and retract the cylinders to prevent them from dampening the spring force. Lastly, we release the latch and use the spring energy to fire the ball.
http://www.chiefdelphi.com/forums/at...0&d=1203646429
Dan Cell
Systems Eng. Mentor
Team 836 - The Robobee's
Unread 05-03-2008, 10:05
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
For the sixth time...
Simbotics does not use pnuematics to shoot the ball. They tension it using surgical tubing and wind it back with a motor. The only pnuematic shooter I saw was 1024. The lifted the ball to about a 5' level before shooting it with what appeared to be 4 3/4" bore pistons.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 05-03-2008, 10:42
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
Team 1771 uses pneumatics to launch. We are acquiring and holding with a vacuum device. When we launch, the vacuum holds the ball until it develops sufficient force to break the vacuum. It works very well.
Video here:
http://www.youtube.com/watch?v=QeQSGmFnKAE
More details here:
http://www.chiefdelphi.com/forums/sh...highlight=1771
Former Mentor Team 1771
Former mentor Team 4509
Unread 05-03-2008, 11:08
Jherbie53's Avatar
Jherbie53 Jherbie53 is offline
Hoshua The 2nd
AKA: Joshua aka "Hosh"
FRC #0085 (Built On Brains B.O.B.)
Jherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to behold
Send a message via Yahoo to Jherbie53
I believe we are using either 2" or 1 1/2" bore cylinders, most likely the 2" bore, that have a 6" stroke. We used three storage tanks right before the cylinders, they all tie together after the valves. I don't have any good pictures, but I do have a youtube video.
If you want to see us on a field, you can watch our matches from St. Louis on the blue alliance site.
Unread 05-03-2008, 11:17
1086VEX's Avatar
1086VEX 1086VEX is offline
VA FIRST Alumni
AKA: Alex Curfman
FRC #0384 (Sparky)
1086VEX is a glorious beacon of light1086VEX is a glorious beacon of light1086VEX is a glorious beacon of light1086VEX is a glorious beacon of light1086VEX is a glorious beacon of light
we (1086) uses 4 8" stroke 3/4" or 1" bore(im not sure) pistons to launch the ball. we can launch the ball around 10' in the air and a pretty far distance as well (like over our overpass from our opponents side of the field ). it just took some time to find the right hight for the launcher and the right angle for the piston mounts. it is deffinetly very effective.
you can check us out this weekend at VCU!!
Unread 05-03-2008, 12:23
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Yea I'll come check you guys out tomorrow. Can't figure out how any of this pneumatic launcher stuff works. It seemed like all of our prototypes of a pneumatic launch were just doomed from the start.
GitHub
Unread 05-03-2008, 13:44
gurellia53's Avatar
gurellia53 gurellia53 is offline
word up
AKA: Andrew G
FRC #1736 (Robot Casserole)
gurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to behold
We're using 2 CIM motors to launch. I guess everyone else is afraid of them.
Is ANYONE else using motors to launch?
And...
here's a video: http://youtube.com/watch?v=NfoPwtG1UGI
some pics:
http://www.chiefdelphi.com/forums/sh...ad.php?t=64406
http://www.chiefdelphi.com/media/photos/30380
FRC
Robot Casserole 1736: 2007 - 2008, 2013 - present
Team Neutrino 3928: 2012
Unread 05-03-2008, 14:09
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
At the end of the season I kicked around building a trackball catapult as a possible project in school and the way I was going to do it was to have a piston retract the catapult and pull some surgical tubing tight. to get the piston to extend with the surgical tubing fast enough I was just going to leave one of the ports open which effectively makes it a spring return style piston. I figured that when you switch the direction of the piston it will almost instantly compress and shoot the ball. I'm not entirely sure it would work but if it did it would be kinda cool.
-Dustin Benedict
Unread 09-03-2008, 18:00
jfc358 jfc358 is offline
FRC #0358
jfc358 is an unknown quantity at this point
<edit>
</edit>
just curios...
-Leav
We originally had a linear cylinder on our arm to push the ball over the overpass. We did some tests with different cylinders, but were not happy with the results. We never tried the latching technique as we decided to build a "drop kick" device. This mechanism used a 1 /12" bore cylinder to kick the ball shortly after it was dropped from our arm. After some debate, and some time lapse photos we realized we had more of a Jai-alai stick. After a few small modications, we came up with a result we much happier with. This mechanism allows us to throw the ball from about 8 feet from the overpass, while we are moving. This gives us enough time to drop and go under overpass without slowing down. It also turned out to help us cradle the ball, before the pickup. This video has been posted before, but for those of you who haven't seen this:
We can't wait for CTR later this week.
http://www.youtube.com/watch?v=N1BZAsH-RYA
Unread 09-03-2008, 18:55
danshaffer's Avatar
danshaffer danshaffer is offline
Stanford 2012
AKA: if it quacks like a duck...
FRC #0008 (Paly Robotics)
danshaffer is just really nicedanshaffer is just really nicedanshaffer is just really nicedanshaffer is just really nice
we use a plain pneumatic shooter, with a twist: a lever arm for a 7:1 mechanical advantage, so that we get more speed and less force.
FRC8 Co-Captain 2007-2008
FRC8 Mentor 2008-present
CalGames Ref 2008, 2009
Stanford 2012, Computer Science
How did you learn to program? vivek16 Programming 20 04-03-2007 18:15
How did you control your Robot? 1? 2? Wheel? How? ChrisCook Control System 9 17-05-2005 21:41
How did you do your axles Justin1636 Technical Discussion 11 04-05-2005 18:04
How did you learn how to use Inventor? Greg McCoy Inventor 26 24-05-2003 01:55
How did you guys manage it? archiver 1999 1 23-06-2002 21:56
