Re: Linear Shooters - How did you do it?
we (1086) uses 4 8" stroke 3/4" or 1" bore(im not sure) pistons to launch the ball. we can launch the ball around 10' in the air and a pretty far distance as well (like over our overpass from our opponents side of the field
). it just took some time to find the right hight for the launcher and the right angle for the piston mounts. it is deffinetly very effective.you can check us out this weekend at VCU!! Last edited by 1086VEX : 05-03-2008 at 11:21. |
Yea I'll come check you guys out tomorrow. Can't figure out how any of this pneumatic launcher stuff works. It seemed like all of our prototypes of a pneumatic launch were just doomed from the start. |
We're using 2 CIM motors to launch. I guess everyone else is afraid of them.
Is ANYONE else using motors to launch? And... here's a video: http://youtube.com/watch?v=NfoPwtG1UGI some pics: http://www.chiefdelphi.com/forums/sh...ad.php?t=64406 http://www.chiefdelphi.com/media/photos/30380 |
At the end of the season I kicked around building a trackball catapult as a possible project in school and the way I was going to do it was to have a piston retract the catapult and pull some surgical tubing tight. to get the piston to extend with the surgical tubing fast enough I was just going to leave one of the ports open which effectively makes it a spring return style piston. I figured that when you switch the direction of the piston it will almost instantly compress and shoot the ball. I'm not entirely sure it would work but if it did it would be kinda cool.
| How did you learn to program? | vivek16 | Programming | 20 | 04-03-2007 18:15 |
| How did you control your Robot? 1? 2? Wheel? How? | ChrisCook | Control System | 9 | 17-05-2005 21:41 |
| How did you do your axles | Justin1636 | Technical Discussion | 11 | 04-05-2005 18:04 |
| How did you learn how to use Inventor? | Greg McCoy | Inventor | 26 | 24-05-2003 01:55 |
| How did you guys manage it? | archiver | 1999 | 1 | 23-06-2002 21:56 |
