Go to Post The best defense is a good offense, never back down - Nawaid Ladak [more]
Unread 05-03-2008, 15:10
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: Help with the IR board
If you checkout the IR schematic in the documents on the First website you will see a note on what to remove and what to add to use an external 5 volt supply.
I wonder why they designed it with a 5V regulator, when they knew we would be connecting to our RC anyway...
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 05-03-2008, 15:20
They give you the option of connecting to a 7.2-12 volt source with regulator or to a 5 volt source without the regulator. Your choice depending on application with the RC (Backup battery) or a custom circuit using a local 5 volt supply. Crafty devils these designers!
need help with ir board shumajax Electrical 2 04-03-2008 16:19
Figure out what's wrong with the IR board sparrowkc Electrical 5 17-02-2008 12:29
HELP!!! STUCK WITH SUB ROUTINES WITH THE IR!!! drewjones13 Programming 1 17-01-2008 20:52
Do you have a problem with the IR Board? DonRotolo Control System 5 07-01-2008 23:57
Please help me with the size of the rotating light!!! bigqueue Technical Discussion 5 21-01-2002 09:40
