Go to Post That's one of the saddest stories I've ever heard. When your green isn't neon enough, you are in big trouble in FIRST. - JaneYoung [more]
Unread 05-03-2008, 15:20
Re: Help with the IR board
They give you the option of connecting to a 7.2-12 volt source with regulator or to a 5 volt source without the regulator. Your choice depending on application with the RC (Backup battery) or a custom circuit using a local 5 volt supply. Crafty devils these designers!
need help with ir board shumajax Electrical 2 04-03-2008 16:19
Figure out what's wrong with the IR board sparrowkc Electrical 5 17-02-2008 12:29
HELP!!! STUCK WITH SUB ROUTINES WITH THE IR!!! drewjones13 Programming 1 17-01-2008 20:52
Do you have a problem with the IR Board? DonRotolo Control System 5 07-01-2008 23:57
Please help me with the size of the rotating light!!! bigqueue Technical Discussion 5 21-01-2002 09:40
