Go to Post I want to wish everyone a Happy Ship Day. - JohnBoucher [more]
Unread 05-03-2008, 18:25
SL8's Avatar
SL8 SL8 is offline
AKA: Jesus
FRC #0647 (Cyber Wolf Corps)
SL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud of
Send a message via Yahoo to SL8
Need help with Kevin's hybrid code?
Is there some way that we can implement Kevin's code for IR without using your code?
I only modified the default code in MPLab and the created the same effects in easyC.
If need be, I may end up using your code, but I was wondering if we would only have to implement Specific parts?
-Jesus
Unread 06-03-2008, 16:02
Steve_Alaniz Steve_Alaniz is offline
FRC #2848 (All Sparks)
Steve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond repute
Re: Need help with Kevin's hybrid code?
Could you be a bit clearer in what you are asking? Not sure who "you" and "your" refer to. Sounds like you want to implement KW's IR code in Easy C...is that correct? Or are you saying you have already done that?
Steve
Unread 06-03-2008, 17:07
Kevin Watson's Avatar
La Caņada High School
FRC #2429
-Jesus
If you want to drop the IR code into an existing MPLAB project, it should be fairly easy to do. Probably the hardest part will be setting up the interrupt service routine in user_routines_fast.c, but you should be able to get plenty of help here.
-Kevin
Kevin Watson
http://kevin.org
Unread 06-03-2008, 17:32
SL8's Avatar
SL8 SL8 is offline
AKA: Jesus
Steve
Sorry, I was very tired and wrote the post as though I was speaking to Kevin
Unread 06-03-2008, 17:33
SL8's Avatar
SL8 SL8 is offline
AKA: Jesus
-Kevin
Thank you, do I have permission to pm or email you if I need help?
Unread 06-03-2008, 22:36
FRC #2429
Yes.
-Kevin
Kevin Watson
http://kevin.org
Help with Hybrid code ShotgunNinja Programming 1 15-02-2008 13:42
Need help in Kevin's 2008 default code robotrobot2 Programming 5 20-01-2008 14:36
Problem with Kevin's code Tottanka Programming 5 04-11-2007 13:32
What are with the Ls in Kevin's code??!!! HELP!!! RbtGal1351 Programming 2 18-02-2005 16:57
hey need some help with writing a code please help me here magical hands Programming 9 01-01-2004 21:46
