Go to Post Baker, you're making my head hurt and it's only August!!!! - Rich Kressly [more]
Unread 05-03-2008, 18:50
JHSmentor's Avatar
JHSmentor JHSmentor is offline
AKA: Bryan Molloseau
FRC #3210 (Falcons)
JHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to all
Re: Are we the only Hearder in this game?
Team 2374 from Oregon was a "herder" of sorts. We had arms to control the ball but found that they were in the way most of the time so we didn't use them. But, dislodging the ball was our specialty and was very valuable throughout the matches. We were picked for an aliance by 2046 for the elimination rounds and made it to the finals (as a rookie team). so, running laps, dislodging the ball, herding, and playing defense is a huge deal.
Unread 05-03-2008, 18:55
XaulZan11's Avatar
XaulZan11 XaulZan11 is offline
AKA: John Christiansen
FRC #1732
XaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond repute
Send a message via AIM to XaulZan11
I believe 2041, Midwest winner, was also a hearder. They had a clean ball pick-up method, and a great strategy in QF4-1 to bring the other ball around the track so 1114 had two ball to score with, leading to a high score.
Unread 05-03-2008, 19:01
Goaliexam Goaliexam is offline
AKA: Max
FRC #1656 (Haverford Robotics)
Goaliexam is a jewel in the roughGoaliexam is a jewel in the roughGoaliexam is a jewel in the rough
Send a message via AIM to Goaliexam Send a message via MSN to Goaliexam
Team 1656 is a herder bot, with a method of knocking down the balls from the overpass. We'll be competing at Chesapeake this year.
Unread 05-03-2008, 19:17
Lions for First's Avatar
Lions for First Lions for First is offline
AKA: Devan
FRC #2365 (Lions Robotics)
Lions for First has a spectacular aura aboutLions for First has a spectacular aura aboutLions for First has a spectacular aura about
Send a message via AIM to Lions for First
team 2365 is a herder that can knock down trackballs we will be at AZ tomorrow
2008 AZ Regional: Highest Rookie Seed
5th seed alliance Cap.
Semi-finalists (thanks 125 and 842)
Unread 05-03-2008, 19:50
seanl's Avatar
seanl seanl is offline
"The Everything person"
FRC #0867 (Absolute Value)
seanl will become famous soon enoughseanl will become famous soon enough
wow that is relieving
, Sean
TEAM 867
-electrical
-pneumatics
-programming
2008 Autodesk Visualization Grand Prize Winner
Unread 19-03-2008, 21:21
EricVicenti EricVicenti is offline
FRC #0008 (Paly Robotics)
EricVicenti has a spectacular aura aboutEricVicenti has a spectacular aura aboutEricVicenti has a spectacular aura about
I think the problem with herding is that in many cases it is mathematically unwise to herd. If the ball is left on the overpass for the entire match, it gains 12 points, so to compensate for the 12 points that you likely loose by using the ball at all, you need to do 6+ herds.
This is of course operating under a number of assumptions. For one, it assumes the opposing alliance would not knock your ball down by the end of the match.
I remember one team during a practice match at SVR lost against nobody because they knocked down both of their color balls and made 2 laps. Because the 2 opposite color balls remained, they lost 24-4.
Unread 10-04-2008, 22:00
David Noll's Avatar
David Noll David Noll is offline
FRC #0555 (Montclair Robotics)
David Noll will become famous soon enough
Send a message via AIM to David Noll
Herders shouldn't focus on herding. Knock the ball down if you can and lap. The biggest thing though, and few people have been working on it, defense! Knock the other teams ball around, you see 'em going in for it, give them a love tap so they have to get moving. Even if you don't knock down show us you can lap and block, then you will get picked.
To learn is as to read, to retain the essential and forget the non-essential. Always in the pursuit of knowledge.
Unread 10-04-2008, 22:16
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Tell that to Rage 173 . They've put up more points with "2 and 2's" (herd+lap) than some hurdlers I've seen.
Unread 11-04-2008, 16:52
XaulZan11's Avatar
FRC #1732
I have to second that. I just prescouted them and was very impressed. I didn't think a herder had much of a chance getting selected for eliminations before I watched some of their matches. A very good hybrid paired with good knock off and solid driving make them a very valuable partner in an alliance with 2 hurdlers (or any alliance for that matter).
Unread 11-04-2008, 17:02
Elgin Clock's Avatar
FRC #0237 (Black Magic)
There were a ton of Herders in NYC. More than any of the 3 other regionals I went to and saw this year.
Some teams just decide to take on the sure thing part of the game, than challenge themselves to go big.
It's all about what you want to do in the game. Nothing wrong with that.
Unread 11-04-2008, 17:45
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
IMO,
herding the ball will have the same/similar impact as scoring 1 point balls in the corner goals of Aim High 2006, generally speaking.
Wont go into details but you get the drift. Lets remember that this is championships, where there will be a greater no. of offensive scoring robots than regionals in general, especially during the elimination matches.
Order of importance from what I've observed this season due to strategies, points awarded, and how many matches were won.
1. Hurdling
2. Hybrid
3. Placing balls
4. Laps
5. Knocking balls down. (ranked lower because you dont always have to do it).
6. Herding
Unread 11-04-2008, 17:58
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
Herding seems unimportant in this game, that is until you have a tie or a match decided by just a few points!
Effective herders require superb maneuverability to control the balls while zooming around the track. Good driving is important, to say the least.
Herding robots can also play effective defense and are a good partner for an alliance with two good hurdlers. Herding a ball to a good hurdler is not a bad strategy.
Your not the only herder, we're just a quiet (and perhaps a bit under-appreciated) group!
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Unread 12-04-2008, 19:50
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Originally Posted by waialua359 View Post
IMO,
Which means we should see at least one robot in the Einstein Finals doing it
Unread 10-04-2008, 23:14
DarkFlame145 DarkFlame145 is offline
That guy
AKA: Dennis
no team (None this season)
DarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud of
Send a message via AIM to DarkFlame145
We could hurdle and knock down the ball in hybrid, but we did mostly laps/herding with our flippers and hybrid mode.
TR-X 145 of Norwich, NY: Student 2005-2008
Exploding Bacon 1902 of Winter Park, FL: Mentor 2009
US Navy Corpsman 2011-????
Unread 11-04-2008, 01:32
Coach Norm Coach Norm is offline
Team 2468 Coach/Adviser
AKA: Norman Morgan
FRC #2468 (Team Appreciate)
Coach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond repute
We are a herder with the ability to knock the ball down during autonomous and get four lines in hybrid. We placed 5th overall at LSR and won the Rookie All Star. We have improved our autonomous. Our average at LSR was nearly 26 points a round. We did not have the ability for knocking off balls very functional then. We have worked to improve it.n Our speed is 15 f/s as well.
We think a herding/defensive bot is beneficial to two hurdling bots. You have the ability to dislodge opponents balls as they try to control them as well as move balls into position for hurdlers and then zoom around to get more laps and points.
Good luck to fellow hurder and lap bots.
FRC 2468 Team Lead 2008 - Present
Win The Day!
Are you actually limited to only the three prompts? darsh5000 3D Animation and Competition 9 14-01-2007 03:18
are this year's fisher price motors as good as the old ones with the black case? waialua359 Motors 2 11-01-2007 22:51
Am I the only person with this job? A. Leese General Forum 55 22-06-2006 20:10
The Answer to this years game - 42! Ashley Christine Chit-Chat 19 16-01-2006 23:22
The key to this year's game (long) archiver 2001 6 23-06-2002 23:05
