Go to Post This only gets awkward when the girl knows more digits of pi than you do... - Walter Deitzler [more]
Unread 06-03-2008, 09:11
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
4V - 5V signal on Digital Input
We have an input signal that is at 4V when it is low, and at 5V when it is high. How could we bring the voltage down so that we can read it in as a digital input?
And no, analog inputs are not an option
Unread 06-03-2008, 09:49
dcbrown dcbrown is offline
AKA: Bud
dcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud of
Re: 4V - 5V signal on Digital Input
The first thing that comes to mind is a simple level triggering opamp circuit? For example LM339s or LM139s? Set up a resistor divider so that 4.1v is Vref, apply your 4v-5v to Vin, Vout should be ~0v if Vin is less than 4.1v and ~5v is greater than 4.1v...
See National Semi AN-74.pdf application note for more info.
Unread 06-03-2008, 10:20
Ken Streeter's Avatar
Ken Streeter Ken Streeter is offline
Let the MAYHEM begin!
FRC #1519 (Mechanical Mayhem)
Ken Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond repute
Do you mind my asking why analog inputs are not an option? Are you already using all of the analog inputs on the controller?
If you need to use a digital input, the suggestion of using an LM339 (4 comparators in a package) or an LM393 (2 comparators in a package) is a good approach.
Data sheets can be found online:
Ken Streeter - Team 1519 - Mechanical Mayhem (Milford Area Youth Homeschoolers Enriching Minds)
2015 NE District Winners with 195 & 2067, 125 & 1786, 230 & 4908, and 95 & 1307
2013 World Finalists & Archimedes Division Winners with 33 & 469
2013 & 2012 North Carolina Regional Winners with teams 435 & 4828 and 1311 & 2642
2011, 2010, 2006 Granite State Regional Winners with teams 175 & 176, 1073 & 1058, and 1276 & 133
Team 1519 Video Gallery - including Chairman's Video, and the infamous "Speed Racer!"
Unread 06-03-2008, 14:51
Thanks guys, I'll look into those options. The only reason we don't want to use analogs is because we're really just looking for on vs. off, and the additional sampling required for using an analog input is overkill.
Unread 06-03-2008, 15:30
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
It may be overkill, but if the custom circuit's output does not operate such that it meets the designed parameters of the RC, then you need to adjust your approach.
An analog comparison will only take a couple lines of code.
char a;
if (Get_analog_01() <= 800)
a = 0;
else
a = 1;
Unread 06-03-2008, 19:06
AKA: Dr. Brooks
no team (WRRF)
Building custom circuitry, when the an analog input can get your
on-off state is overkill. We ran out off digital inputs this
year and needed one more. We wired the switch to a
pullup resistor and an analog input, coded to set a variable to 0 when
the voltage was below 2.5 volts and to 1 when the voltage was
above. It worked just fine.
Eugene
Digital out signal speed on off, almost like PWM but at max 60Hz Generalx5 Electrical 2 27-03-2007 12:26
Auton digital input ten3brousone Programming 7 20-03-2005 22:23
digital input question... Kevin Karan Programming 9 12-04-2004 07:34
counting digital input CharlieWilken Programming 9 22-03-2004 19:56
Robot Digital Input Mike Norton Technical Discussion 5 16-01-2003 14:31
