Go to Post If you look closer, you'll see I did those photos over a period of years... and they were only done with one program... but yeah, a little free time with no where to direct it and I can become, um, creative... - MissInformation [more]
Unread 05-03-2008, 19:32
Golto's Avatar
Golto Golto is offline
AKA: Pat Plude
FRC #4572 (BArlow RobAutics)
Golto is a glorious beacon of lightGolto is a glorious beacon of lightGolto is a glorious beacon of lightGolto is a glorious beacon of lightGolto is a glorious beacon of light
IR not changing state or var
Hello everybody! I have an interesting dilemma!
I have mapped the IR board to Digital Input 1-4 on the RC, and called these to be read in Autonomous.
Now, When a button is pressed on the remote in Hybrid, the status of the variable won't change. Though if I am holding the button and reset the robot the variable changes?!
I do not believe that Autonomous is being called after the first routine. As in, I think it's just doing the default and kicking out, rather than looking for the variable.
I am including the code for the autonomous (I program in EasyC and am using the code box on the right to copy this, by hand, my laptop has not network.) I only copied 1 output code, the others are copied from the "IF (Out0 =1)" block, and modified for their function
#include "Main.h"
void Autonomous (void)
unsigned char Out0 = 0 //IR Output 0
unsigned char Out1 = 0 //IR Output 1
unsigned char Out2 = 0 //IR Output 2
unsigned char Out3 = 0 //IR Output 3
signed char count = 0 //Smart Counter
while (1 == 1)
  Out0 = GetDigitalInput (1);
  Out1 = GetDigitalInput (2);
  Out2 = GetDigitalInput (3);
  Out3 = GetDigitalInput (4);
  if (Out0 = 0)
    if (Out1 = 0)
      if (Out2 = 0)
        if (Out3 = 0)
          // ADD DRIVE CODE HERE
          for (count; count = 0; count ++)
            Wait (300);
          for (count; count = 1; count ++)
            Wait (200);
          for (count; count = 2; count ++)
            Wait (200);
          for (count; count = 3; count ++)
            Wait (200);
          for (count; count = 4; count ++)
            Wait (1500);
          for (count; count = 5; count ++)
            Wait (500);
          for (count; count = 6; count ++)
            Wait (500);
          for (count; count = 7; count ++)
            //STOP HERE!
  if (Out0 ==1) //Button 1 pressed
    Out1 = 0;
    Out2 = 0;
    Out3 = 0;
    SetDigitalOutput (15, 1) // LED1 ON
    SetDigitalOutput (16, 0) //LED2 OFF
    SetDigitalOutput (17, 0) // LED 3 OFF
    SetDigitalOutput (18, 0) //LED4 OFF
    if (count <=3)
      //SET RELAYS OFF!!!
      count = 4;
   else
      count = count;
    break;
//COPY OUT0 AND MODIFY FOR OTHER MODES
// END AUTO
Unread 05-03-2008, 23:47
SL8's Avatar
SL8 SL8 is offline
AKA: Jesus
FRC #0647 (Cyber Wolf Corps)
SL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud of
Send a message via Yahoo to SL8
Re: IR not changing state or var
I would like to help but I can not understnd what your code is supposed to do, could you clarify it?
Unread 06-03-2008, 00:26
Your first few if statements are setting variables to zero instead of testing for being equal to zero. Replace the = 0 with == 0 to fix that.
I don't understand what the for statements are supposed to be doing. The initialization does nothing, and I suspect you've made the same = vs. == error in the continuation check.
Unread 06-03-2008, 05:48
Golto's Avatar
AKA: Pat Plude
Thanks.
The FOR statements are only to keep the counter time.
There is a 7-step autonomous that can be interrupted by the IR commands. The counter is so it can pick up where it left off.
Otherwise, I'll change the operators and cross my fingers!
Unread 06-03-2008, 13:56
SL8's Avatar
SL8 SL8 is offline
AKA: Jesus
You are probably correct, I can't believe I missed that. Everyone makes mistakes.
Unread 06-03-2008, 14:10
BHOP BHOP is offline
FRC #0399 (Eagle Robotics)
BHOP has much to be proud ofBHOP has much to be proud ofBHOP has much to be proud ofBHOP has much to be proud ofBHOP has much to be proud ofBHOP has much to be proud ofBHOP has much to be proud ofBHOP has much to be proud of
I'm sure pretty your while loop isn't going to do anything because auto gets called in main.c every 26ms or so. so even though you are trying to get stuck in the while loop with 1==1, your not stuck because auto will just get called again.
I'm not entirely sure, but I think this is one problem. (I'm kinda new at this)
BHOP
ME CoE University of Michigan
503 Frog Force 830 Rat Pack
399 Eagle Robotics
Unread 06-03-2008, 15:48
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
BHOP - easyC / WPILIB will only call the autonomous() function once when the field switches. Also, everything you do in easyC / WPILIB runs at full speed in the user processor. So, his while(1==1) will loop as fast as it can. Any commands going to the Master Processor ex. PWM/OI will sync every 26ms due to the nature of how the master processor is programmed by IFI. But, in this case all the inputs are tied directly to the user processor so the 26ms loop doesn't apply.
Unread 06-03-2008, 16:45
thanks for that info...i've never tried easyc
BHOP
399 Eagle Robotics
Hawaii Gov. Lingle State of State speech-FIRST and STEM MoeMom FIRST In the News... 0 29-01-2008 17:04
Code not changing robots function! popo308 Programming 3 25-01-2008 11:17
OI digital inputs and Var res switches. Gdeaver Control System 1 16-10-2007 13:17
Encoders not changing... paulcd2000 Programming 28 18-02-2007 08:34
::CHANGING SERVERS:: Brandon Martus General Forum 5 21-12-2001 10:33
