Need help with Kevin's hybrid code?
Is there some way that we can implement Kevin's code for IR without using your code?
I only modified the default code in MPLab and the created the same effects in easyC. If need be, I may end up using your code, but I was wondering if we would only have to implement Specific parts? -Jesus |
Re: Need help with Kevin's hybrid code?
Could you be a bit clearer in what you are asking? Not sure who "you" and "your" refer to. Sounds like you want to implement KW's IR code in Easy C...is that correct? Or are you saying you have already done that?
Steve |
-Kevin |
Thank you, do I have permission to pm or email you if I need help?
Yes.
-Kevin |
| Help with Hybrid code | ShotgunNinja | Programming | 1 | 15-02-2008 13:42 |
| Need help in Kevin's 2008 default code | robotrobot2 | Programming | 5 | 20-01-2008 14:36 |
| Problem with Kevin's code | Tottanka | Programming | 5 | 04-11-2007 13:32 |
| What are with the Ls in Kevin's code??!!! HELP!!! | RbtGal1351 | Programming | 2 | 18-02-2005 16:57 |
| hey need some help with writing a code please help me here | magical hands | Programming | 9 | 01-01-2004 21:46 |
