Go to Post FIRST, an american revolution. - paulcd2000 [more]
Unread 06-03-2008, 17:33
SL8's Avatar
SL8 SL8 is offline
AKA: Jesus
FRC #0647 (Cyber Wolf Corps)
SL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud of
Send a message via Yahoo to SL8
Re: Need help with Kevin's hybrid code?
Originally Posted by Kevin Watson View Post
If you want to drop the IR code into an existing MPLAB project, it should be fairly easy to do. Probably the hardest part will be setting up the interrupt service routine in user_routines_fast.c, but you should be able to get plenty of help here.
-Kevin
Thank you, do I have permission to pm or email you if I need help?
Help with Hybrid code ShotgunNinja Programming 1 15-02-2008 13:42
Need help in Kevin's 2008 default code robotrobot2 Programming 5 20-01-2008 14:36
Problem with Kevin's code Tottanka Programming 5 04-11-2007 13:32
What are with the Ls in Kevin's code??!!! HELP!!! RbtGal1351 Programming 2 18-02-2005 16:57
hey need some help with writing a code please help me here magical hands Programming 9 01-01-2004 21:46
