Go to Post Roses are red/Violets are blue/I'll write a poem/Once build season's over. - Taylor [more]
Unread 06-03-2008, 19:24
gwt8641 gwt8641 is offline
FRC #1728
gwt8641 is an unknown quantity at this point
Re: New C18 3.0+ Compatible FRC Code
Originally Posted by Kevin Watson View Post
I've received quite a few e-mails and PMs with positive feedback on the code (team 1024 used the code in Chicago last week and won). Two people have had problems, but one turned out to be a call to printf() inside an interrupt service routine that was quickly fixed. Tom Bottiglieri is having a weird issue with the RC occasionally throwing the red-light-of-death when it's cold booted, but it's not clear to me what is causing the problem.
If you want, you can zip up your code and send it to me for a quick look.
-Kevin
I'm sorry, I think my first post came across as more accusatory than I intended. Kevin, you did an awesome job with this code and your work is much appreciated. I've been using various bits of your code for years now with great success. My reason for posting was hope that someone else had encountered the same problem we hit and had a simple solution.
I'm still not sure exactly what is going on. Reloading the user program to our RC seems to briefly fix the problem, leading me to believe that this program is somehow becoming corrupt. I no longer believe Kevin's 3.0 compatible code to be contributing in any way (and I'm glad to be using it!)
Kevin, I'll still zip and send you our program.
Thanks all!
Greg
Does the camera code suits to all versions of MPLAB and C18? razer Programming 3 04-01-2007 14:50
Trying to follow C18 interrupt context code... dcbrown Programming 5 21-12-2006 09:01
Error w/ FRC code JamesBrown Programming 2 08-01-2005 16:17
Programming code Fix FRC Ferazel2001 Programming 6 08-02-2004 02:46
FRC default code hedgehogger Programming 2 21-01-2004 18:41
