#13
Re: Interrupts, Interrupts, and more Interrupts!
Right, but the entire data structure is not. Look at how the IFI default code works -- it treats some of the PWM outputs as temporary locations before finishing the single-joystick mixing. This works fine when the get/put is done explicitly. If you have a need to coordinate values, you have to consider the possibility that the EasyC magic communication might happen when you've started setting them but haven't completed setting them all.
| How many interrupts is too many interrupts? | Madison | Programming | 14 | 08-02-2008 12:09 |
| More than 6 RC digital input interrupts? | Jared Russell | Programming | 2 | 06-02-2007 15:41 |
| Interrupts and Script Conundrums | Jon236 | Programming | 2 | 08-02-2005 23:01 |
| interrupts and putdata() | doy | Programming | 4 | 23-02-2004 22:45 |
| Interrupts and rotation sensors | kor | Programming | 3 | 12-02-2004 11:05 |
