Go to Post "Things don't get done unless somebody does them." - CaptainKirby [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
Unread 04-03-2008, 09:34
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
Re: 2008 Team 1511 Scouting Database
Originally Posted by zivo123 View Post
im not sure i've understood it.. does it need labview installed? or just excel?
other than that it really looks great!
thanks!
Hmm, I hope not. That may be why I'm getting the error. Still not at my laptop now, but I noticed it asks for the installation location of LabView.
The difference between theory and application is that in theory, theory and application are the same; In application, they are not.
Unread 04-03-2008, 23:20
Larry Lewis's Avatar
Larry Lewis Larry Lewis is offline
The Spiky Hair Guy
FRC #1511 (Rolling Thunder)
Larry Lewis is a name known to allLarry Lewis is a name known to allLarry Lewis is a name known to allLarry Lewis is a name known to allLarry Lewis is a name known to allLarry Lewis is a name known to all
It seems like there are some questions with the installation or configuration of the database. Make sure you read through the read me file located in the following location if you use the default installation path.
C:\Program Files\Team 1511 Scouting Database\data\read me.doc
This may help a little bit with the setup of the program.
Ok so here are some tips for installing.
You NEED to have Microsoft Excel installed on the computer you are running the database on. The database does uses Excel to build the datasheet where all the information is contained.
When you first run the program you will notice that only the configuration menu button is shown. I did this to ensure that the database is configured correctly before you start to read or write data. This was my way to allow users to select the path of an existing spreadsheet that they want to use instead of making the file mandatory in a set location. That being said make sure that you click the Change Filepath of Database button and browse to the spreadsheet you want to use. Once you have selected this sheet the program will save your settings and you will no longer need to link to that sheet. I hope this helps with some of the database file configuration issues.
Networking
Yes you can network together multiple computers and have it write to one database file. This is the way that we currently do our scouting. We hook up 7 computers to a router or hub which is the backbone of our network. Really any TCP/IP based network will work. Next is to designate a host computer. I usually pick the fastest one to do this since it has to receive all the information. On that host computer create the spreadsheet you want to use as your database file. Put it in a shared directory that allows access to read and write to that file. On the remaining 6 computers map a drive to the computer on the network to that folder. The next and final step is to go into your configuration menu and select the mapped drive and navigate to the spreadsheet. That should do it. I know it sounds like alot but it is really not that bad once you get it setup.
Once warning I have is to try to not all write to the database at the same time. The program will error saying it cannot write to the database. This is due to the file being locked up. It is not a big deal since it will just go back to the main submission screen and you can try again.
I hope that this helps out anyone that is having any problems getting things installed or configured. If there are any further questions let me know. Due to the recent increase of interest I will try to make it on more. Stay tuned for the next release! Featuring placement of ball on overpass! Thanks!
Also thanks to Kim for filling in for me.
Unread 05-03-2008, 01:10
The Spiky Hair Guy
Here is version 1.0 of the scouting database. Basically it is the same as the previous version but has the addition of the place on overpass input as requested. I will try to work in some of the other suggestions I have received in this thread and release them in later versions.
I also noticed that when you first run the database and open the configure menu it prompts you to select the database automatically but in the windows default directory. Navigate to the following directory or select another spreadsheet file to get things going.
C:\\Program Files\Team 1511 2008 Scouting Database\data\Scouting Database.xls
At this point I would also like to thank Danny Diaz from Team 418. Without his help none of this would be possible. Thanks!
Unread 05-03-2008, 01:12
The Spiky Hair Guy
Sorry kinda late. I forgot the link! Here is the path to the zip file for version 1.0 of the database.
http://www.penfieldrobotics.com/scou...abase_V1.0.zip
Unread 06-03-2008, 23:09
Troyness Troyness is offline
FRC #0573
Troyness is an unknown quantity at this point
When you network a single database, do all of the computers need excel or just the host computer?
Unread 13-03-2008, 20:49
The Spiky Hair Guy
Unfortunately all the computers will need Excel to run the program. I am thinking for next year I will try to remove the dependency on Excel from the program but for this year Excel will be needed.
Unread 13-03-2008, 21:54
Grandma's Avatar
Grandma Grandma is offline
AKA: Jasper
FRC #2506 (Sabers)
Grandma is an unknown quantity at this point
Wink Re: 2008 Team 1511 Scouting Database
we had a scouting sheet that was very similiar. hey we might've even stole from you guys
Unread 19-03-2008, 19:21
The Spiky Hair Guy
Not a problem! :-) Really the point of all of this is help out other teams. That is why I put up the source code and the program itself. Plus, this is only a way to store and retrieve the data, it doesn't tell you how to analyze it...yet.
[IMG] code is Off
Scouting Database merybar General Forum 2 31-01-2008 19:21
1511 LabVIEW Scouting Database Release Larry Lewis Scouting 7 02-08-2007 15:18
paper: 2007 Championship Event Scouting Database, presented by Team 1114 Karthik Extra Discussion 18 10-04-2007 17:02
Team 48's Scouting Database Shelley_delphi chick Scouting 11 28-05-2002 02:14
Scouting Database yanika123 General Forum 19 11-10-2001 17:09
