Go to Post Wait - a single message outlining the vast majority of where to find controls stuff? Goodness. What will they think of next. - Tom Line [more]
Unread 07-03-2008, 14:05
114Klutz 114Klutz is offline
AKA: Li Pi
FRC #2984 (Viking Robotics)
114Klutz is a jewel in the rough114Klutz is a jewel in the rough114Klutz is a jewel in the rough
Send a message via AIM to 114Klutz
Signalling Methods during Hybrid
In Hybrid mode, the rules do not specify that IR must be used to signal the robot, are any other more reliable signaling methods which are legal and easily implementable?
Unread 07-03-2008, 14:35
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: Signalling Methods during Hybrid
RF will give you extended range and I think they mention that is ok in the rules.
Ponders......
I wonder if using the digital inputs from channel 5 and 6 of a vex remote and outputing from a Vex controller would work......
Unread 07-03-2008, 14:41
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
Not according to this.
Active SIGNALING DEVICES shall:
* use visible light, infrared communications, or sound as the transmission method – no
other form of electro-magnetic radiation is permitted
a. All radio frequency communications (as defined by the United States Federal
Communications Commission) are explicitly prohibited.
b. All laser-based communications by any device classified by the U.S.
Department of Labor Occupational Safety and Health Administration (OSHA)
as a laser are explicitly prohibited.
c. All communications must satisfy Rule <S01>.
Unread 07-03-2008, 14:42
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
RF is specifically PROHIBITED in the rules.
Unread 07-03-2008, 14:45
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Ponders......
From R65:
• use visible light, infrared communications, or sound as the transmission method – no
You may only use IR, visible, or sound. We have implemented a visible light device that will, hopefully, avoid some of the issues other teams have experienced using IR.
Unread 07-03-2008, 15:13
AKA: Li Pi
All such methods are extremely susceptible to interference then, the preference would be a system which is both very distinct, and has enough room for error that interference won't make much of a difference. I was thinking perhaps powerful light with 4 different colors.
Unread 07-03-2008, 15:19
Kingofl337's Avatar
AKA: Adam
oh my bad totally sorry, I thought I read it was ok but obviously I didn't, maybe it was the sound waves I confused it for.....
Poor team scouting methods? jumpe1990 Scouting 36 24-03-2008 14:11
Balls during Hybrid Mode geekofband007 Rules/Strategy 7 12-01-2008 20:34
Methods of communication???? aviv Chairman's Award 3 18-02-2006 20:10
Methods of Solving Differential Equations sanddrag Math and Science 7 26-01-2006 14:38
Methods of Mounting LEDs Matthew_H Electrical 9 21-03-2004 23:15
