Go to Post Either way, I'll stay a FIRSTer for life. =) - Adare180 [more]
Unread 07-03-2008, 21:45
Guy Davidson Guy Davidson is offline
AKA: formerly sumadin
FRC #0008 (Paly Robotics)
Guy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to behold
Send a message via ICQ to Guy Davidson Send a message via AIM to Guy Davidson Send a message via MSN to Guy Davidson
Using Analog Inputs as Digital (on the OI)
Hey folks,
Is there anything we should watch for if we want to use analog inputs as digital? i.e. wire up a binary switch onto one of the analog inputs. Should we wire ground and signal, +5 and signal, or all three?
Thanks,
Guy Davidson
Paly Robotics (FRC #8)
Unread 07-03-2008, 21:52
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
Re: Using Analog Inputs as Digital (on the OI)
tie a 10K resistor from +5 to the analog input pin
connect a switch from ground to the same analog input pin
when the switch is closed you will have a 0
when the switch is open you will have full scale analog value (I don't remember if it is 8 or 10 bit or what)
write some code that interprets
half-scale or lower as a switch closed
else
switch open
Ed Barker
Unread 07-03-2008, 21:53
Ed,
Thank you very much. Sounds good.
Unread 07-03-2008, 23:30
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Just as a reassurance, we are successfully using this on our OI panel this year.
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 08-03-2008, 02:07
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Your description is Spot On.
FYI, RC analog inputs are 10 bits, 0-1023. OI inputs are 8 bit, 0-255.
Unread 08-03-2008, 09:18
O-H
FRC #0048 (Delphi E.L.I.T.E.)
-q
As have we, for many years. We don't use the pullup resistor approach - the ground doesn't appear in our method of wiring switches to analog input. I've never had a problem with this method.
Remember, on the OI, you don't need to have a ground connection for an analog input pot reading - on the joysticks, it's just five volts through the joystick axis pot straight to the analog input. We duplicate this method in wiring digital switches to our analog in's.
For devices such as rocker switches or 3-position toggle switches where only one state can be active at one time due to the mechanics of the device, wire two resistors of differing values (each less than 100K - say 10k and 80k - whatever - I like to pick them to have a distinct separation that can easily be tested for in the code) between the +5V and the different poles of the device. 10k on one pole, 80k on the other. Wire the common of the device to a single analog input.
When you actuate the switch, you connect 5V through either 10k or 80k into the analog input, resulting in a distinct numeric value for each position. Use if statements to test for ranges centered around these values and set binary variables accordingly:
//Wrist Rocker switch on button box
if ((wristrocker > 218) && (wristrocker < 240))  //Wrist Reverse/Up rocker is active
  wristfwd_sw = 0;
  wristrev_sw = 1;
else if ((wristrocker > 73) && (wristrocker < 95)) //Wrist Forward/Down rocker is active
  wristfwd_sw = 1;
  wristrev_sw = 0;
else
 wristfwd_sw = 0;
 wristrev_sw = 0;
Unread 08-03-2008, 09:20
We actually use a simlar method with an 11 position switch and 10 9.1K resistors wired to a joystick analog input, to give us a method of choosing different auto modes.
Unread 08-03-2008, 20:19
AKA: Alex
That's right... we had that problem related to this in one of our practice matches at Chicago. When our automode started one time early on, the arm started trying to fold out while being closed. Turned out, one of the buttons on the OI panel was shorted out (the one for arm fold out) so I figured out that there must be one OI panel read before the autonomous mode enters (as there is one execution of the master uP routine before autonomous mode).
So anyhow, my question for clarification: Al: You guys use a switch on your OI panel, and it gets read by your robot before it starts to run autonomous?
If so... awesome!
-q
Unread 08-03-2008, 20:30
Q, I imagine that the OI is transmitting data throughout autonomous/hybrid mode - it's just that we never find out because it's hands-off.
Unread 08-03-2008, 23:29
Remember that the RC starts to run it's (your) program when you turn it on. The OI does not get a autonomous command until much after you power the robot. During autonomous, all OI analog inputs are held at 127 and all digital inputs at "0". See the IFI Programing Ref Guide for more information. I will let the software guys answer coding questions, electrical provides the switch wired to the inputs defined by the software team.
Unread 09-03-2008, 08:29
O-H
If so... awesome!
-q
This is from back in the day, but it illustrates exactly how we get OI variables stored in memory for autonomous routines to utilize:
http://www.chiefdelphi.com/forums/sh...37&postcount=3
If you happen to read the rest of the referenced thread, ignore all the dissenting statements - we've used this method for years, and it still works fine, including this season.
Next year, with a new control system - who knows.
Unread 09-03-2008, 09:14
EricS-Team180's Avatar
EricS-Team180 EricS-Team180 is offline
SPAM, the lunchmeat of superheroes!
AKA: Eric Schreffler
FRC #0180 (SPAM)
EricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond repute
Just like Al and Travis's teams, we've been using "AiDi"s through the various analog input ports for some years now. Like WildStang (heck we probably got the idea from you guys Al ) we use a rotating 6 to 10 position switch with resistors in series. And, like Travis pointed out, we leave plenty of "room" for selecting which position we want. Here's a sample of how we do it.
const uint8 AUTONOMOUS_ANALOGS[7] = {6, 140, 160, 190, 210, 235, 255};
uint8 AnalogToDigital(uint8 value, uint8 analogs[])
  uint8 loop;
  for (loop = 1; loop <= analogs[0]; loop++)
    if (value <= analogs[loop])
      return ( analogs[0] - loop ) ;
  return 255;
The values in the array are the max loop counter, followed the boundaries between which the actual inputs will lie.
Eric
Don't PANIC!
S. P. A. M.
Unread 09-03-2008, 09:47
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
-q
We did this as well in 2005-2006 robots.
Basically we had a thumbwheel through one of the joystick ports. thumb,trigger, aux1, aux2. BCD 1,2,4,8.
When we powered up, we captured the inputs from the joystick to a global varible that was frozen. When auto mode started, we read the global varible.
I had heard of some isses (something changed) in 2007 that it wasn't the same. I think Nathan, our programmer worked through that, not sure what they came up with. So this year, I wasn't sure what to tell them so I suggested to move them since we had so many modes on the robot, we decided to move the thumb wheels back to the RC controller because we have three thumb wheels now.
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 09-03-2008, 14:50
Mark Pierce Mark Pierce is offline
FRC #0085 (B. O. B.)
Mark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant future
Team 85 has used three 12 position switches for several years now. One sets the autonomous path. Others are used for selecting debug information to be sent out the programming port and displayed on the OI. In the pit or on the field we can easily check backup battery voltage, joystick centering, and other values. We also mount a 100K pot to that's handy when developing code or trying out parameters.
Unread 10-03-2008, 16:29
Hmm. I'm just about to wire the switch, and I'm wondering if I really need a connection to ground. Shouldn't I just be able to wire: +5 aux -> 10k resistor -> switch -> analog input, all in series?
We need help with the analog inputs M_dalgashon Programming 4 08-02-2008 17:39
Code to Read the Binary Inputs on Analog Buttons Kingofl337 Control System 5 14-03-2007 11:01
Set Default Digital inputs to Low? How? bad Analog value? Generalx5 Programming 11 04-01-2007 18:57
How do the Analog Inputs work? JBotAlan Electrical 3 07-01-2005 00:11
Analog vs Digital inputs? f22flyboy Programming 8 08-11-2002 22:18
