Go to Post Thanks and don't stay up all night waiting for Lavery Claus! - Beth Sweet [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
  #106   Spotlight this post!
Unread 07-03-2008, 21:15
pentau pentau is offline
AKA: Will
FRC #0449 (Blair Robot Project)
pentau is a glorious beacon of lightpentau is a glorious beacon of lightpentau is a glorious beacon of lightpentau is a glorious beacon of lightpentau is a glorious beacon of light
Send a message via AIM to pentau
Re: Archiving Recorded Regionals 2008
Originally Posted by Kyle Fenton View Post
iMovie would be able to do this, assuming you have a big enough hd for the footage.
Any ideas on how much space would be needed for the three days of footage? 20 gigs? 40? I need to know if I need to bring an extra hard-drive...
Thanks!
  #107   Spotlight this post!
Unread 07-03-2008, 21:37
Kyle Fenton Kyle Fenton is offline
GET IT ON!!
FRC #0121 (Rhode Warrior)
Kyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud of
Send a message via AIM to Kyle Fenton
Thanks!
DV at 720x480 (SD) is typically 1 gb for every 10 minutes. It is a very large lossless format that is mainly used in digital video editing. Is there any other codec you could use?
Rhode Warriors
NAVSEA/Raytheon/URI/Middletown, Portsmouth, Tiverton, Mt. Hope HS
Quality Robots Since 1996
  #108   Spotlight this post!
Unread 07-03-2008, 22:48
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
I've created a page on FIRSTwiki to store all of the information about archiving and webcasting in one place. I've tried to fill in what I could, but that's not much.
If those of you with experience could add to it, that would be very helpful to all of us who are doing this for the first time.
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
  #109   Spotlight this post!
Unread 08-03-2008, 00:08
DeAnnaC DeAnnaC is offline
FRC #1094 (River City Robots)
DeAnnaC has much to be proud ofDeAnnaC has much to be proud ofDeAnnaC has much to be proud ofDeAnnaC has much to be proud ofDeAnnaC has much to be proud ofDeAnnaC has much to be proud ofDeAnnaC has much to be proud ofDeAnnaC has much to be proud ofDeAnnaC has much to be proud of
We used a Panasonic DVR (it has a hard drive and a DVD burner) to record the St. Louis Regional. It had 19 hours of hard drive space available. It was recorded in SP mode and after it was split on the recorder, it took 6+ DVD's to copy the data to, which was then reformatted on the pc and trimmed up before uploading.
I'm not sure if that helps or not..
  #110   Spotlight this post!
Unread 08-03-2008, 12:23
AKA: Will
Thanks for the information. Does anyone know a better way to record on a mac? Are there any programs that just can record video feeds from a firewire input? Or can you just change the import format in iMovie? (The computers we will be recording with aren't with me right now) Thanks!
  #111   Spotlight this post!
Unread 08-03-2008, 13:33
GET IT ON!!
That depends on your input device. Some are DV only, some could encode into MPEG-4 or divx also.
What I use is a cheap DVD recorder from Panasonic. Its great, and I don't have to worry about anyone steeling an expensive laptop. A PVR would be a better solution, because you wouldn't have to worry about the switching the DVDs.
If you are looking for a good input device for your laptop you can check out El Gato's Hybrid or the 250 +. Both can encode a lot of video without using a lot of disk space.
Rhode Warriors
  #112   Spotlight this post!
Unread 08-03-2008, 13:57
AKA: Will
I have a Sony DVMC-DA2 (Maybe a DA1). (http://www.shopping.com/xPF-Sony-DVMC-DA2-DVM-CDA2) Does anyone have any experience recording regionals with them? They seem to have some sort of hardware conversion system...
  #113   Spotlight this post!
Unread 09-03-2008, 16:40
ham90mack's Avatar
ham90mack ham90mack is offline
President of RIT FIRST
FRC #0073 (The Illumination)
ham90mack is just really niceham90mack is just really niceham90mack is just really niceham90mack is just really niceham90mack is just really nice
What I have always done with capturing MiniDV video to my computer is to capture it in DV format (1 hour is from 11-14 GB ), transcode it to DivX (1 hour is usually between 800 MB and 1.5 GB, depending on original quality and randomness of video), and delete the original video. You could probably transcode to mp4 instead if you wanted too, just as long as the quality stays near the same. This method especially helps when needing to capture 15+ tapes for a video project .
Old stuff:
FRC 2007 Strategy Solver. Version: 2.55. Progress: done.
  #114   Spotlight this post!
Unread 09-03-2008, 17:44
AKA: Will
Hmm...sounds good. I am looking into maybe borrowing a faster computer so I can use something like Quicktime Broadcaster (apparently it can record in h.264 to the disk from a DV input). That way I wouldn't have to use so much disk space.
  #115   Spotlight this post!
Unread 12-03-2008, 20:59
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
We still have a couple regionals that need to be covered for week 3, is anyone out there willing/planing to record; Chesapeake Regional, Connecticut Regional, Detroit Regional, Peachtree Regional
Pittsburgh Regional.
Regional                                         Volunteer
Suffield Shakedown
Rochester Rally                                 Ed Patterson (Koko Ed, team 191)
Week 1
BAE Systems Granite State Regional              Kyle Fenton (team 121) *may need parser
Midwest Regional                                WildStang 111 (possibly...)
New Jersey Regional                             SOAP (team 108)
Oregon Regional                                 Madison Krass (M. Krass, team 488)
St. Louis Regional                              DeAnnaC
Week 2
Arizona Regional                                Andrew (Donut, team 498)
Finger Lakes Regional                           Ed Patterson (Koko Ed, team 191)
Greater Kansas City Regional
NASA / VCU Regional                             Anish (aksimhal, team 1123)
San Diego Regional                              AJ (ay2b, team 980)
Week 3
Boilermaker Regional                            Mike Aalderink (mike AA, team 2015)
Brazil Regional                                 sloteera (team 1860), Bruno (Thexder, team 1382)
Chesapeake Regional
Detroit Regional
Florida Regional                                SOAP (team 108)
Peachtree Regional
Pittsburgh Regional
Silicon Valley Regional                         AJ (ay2b, team 980)
Wisconsin Regional                              Kevin Kolodziej  (team 1675)
Week 4
Buckeye Regional                                David Thomas (blakcheez, team 964)
Lone Star Regional                              Kevin Sevcik (team 57)
Los Angeles Regional                            AJ (ay2b, team 980)
Microsoft Seattle Regional                      Madison Krass (M. Krass, team 488)
Oklahoma City Regional
UC Davis Sacramento Regional                    Doug G (team 701)
Waterloo Regional                               Jonathan Norris (team 610)
West Michigan Regional                          Mike Aalderink (mike AA, team 2015)
Israel Regional
Week 5
Bayou Regional
Boston Regional                                 Greg Marra (The Blue Alliance)
Colorado Regional
Great Lakes Regional
Greater Toronto Regional
Hawaii Regional
Las Vegas Regional
Minnesota Regional                              Kevin O'Connor (Vikesrock, team 2175)
Palmetto Regional
Philadelphia Regional
SBPLI Long Island Regional
Championship                                    SOAP (team 108)
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
  #116   Spotlight this post!
Unread 13-03-2008, 12:14
Nancy O.'s Avatar
Nancy O. Nancy O. is offline
sleepy...
FRC #1261 (PRHS Robolions)
Nancy O. is an unknown quantity at this point
We're willing to help record the Peachtree (week 3) and Palmetto (5) regionals, however we're not sure we have the right equipment. We have a member with a RCA cable that he says can plug in to his computer, but is not sure that is the easiest way. Could we use a DVD player or VCR?
(if you didn't know already )
It's easy to regret your awkward conversations but hard to regret the ones you didn't have. (xckd)
"Why?" is powerful, yet infinitely inferior to "Why not?"
  #117   Spotlight this post!
Unread 13-03-2008, 21:09
Chris Marra's Avatar
Chris Marra Chris Marra is offline
The Blue Alliance Staff / 177 Alum
no team (TBA / Bobcat Robotics)
Chris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond reputeChris Marra has a reputation beyond repute
I talked to the crew from 230 who are webcasting the Connecticut Regional. They intend to archive all of the matches to DVD for conversion / parsing later on.
Team 177 - Bobcat Robotics
  #118   Spotlight this post!
Unread 14-03-2008, 19:53
AKA: Will
I recorded all of Chesapeake on Friday in the h.264 format. I plan to do the same tomorrow--I'm just not sure how long it will take me to edit it (cutting out the time between matches and scores, etc) I think some other teams also recorded it? Could we work together?
  #119   Spotlight this post!
Unread 16-03-2008, 14:31
I just purchased a Pinnacle Video Transfer which records in H.264 directly to an external hard drive (no computer needed).
I will be testing it out at the Los Angeles Regional.
  #120   Spotlight this post!
Unread 16-03-2008, 19:00
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Someone was using one of these at Boilermaker this weekend and it seemed to work well and very easy to setup. I was interested, but I dont like the external harddrive thing... although you can swap drives (he used a usb flash drive) and download to a computer.
-Mike
[IMG] code is Off
Getting to the 2008 Honolulu Regionals doesn't require breaking the bank da Marshalls Regional Competitions 113 10-01-2008 13:14
New Regionals in 2008 Madison Regional Competitions 48 14-09-2007 22:53
SVR 2006 Recorded Webcast Joobacca Regional Competitions 3 24-03-2006 08:53
auto archiving of posts Joe Ross CD Forum Support 4 01-01-2004 02:04
automatic archiving Joe Ross CD Forum Support 5 04-08-2003 13:27
