Go to Post The horse is dead; stop beating it please. - DonRotolo [more]
Unread 08-03-2008, 20:19
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Re: Using Analog Inputs as Digital (on the OI)
We actually use a simlar method with an 11 position switch and 10 9.1K resistors wired to a joystick analog input, to give us a method of choosing different auto modes.
That's right... we had that problem related to this in one of our practice matches at Chicago. When our automode started one time early on, the arm started trying to fold out while being closed. Turned out, one of the buttons on the OI panel was shorted out (the one for arm fold out) so I figured out that there must be one OI panel read before the autonomous mode enters (as there is one execution of the master uP routine before autonomous mode).
So anyhow, my question for clarification: Al: You guys use a switch on your OI panel, and it gets read by your robot before it starts to run autonomous?
If so... awesome!
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
We need help with the analog inputs M_dalgashon Programming 4 08-02-2008 17:39
Code to Read the Binary Inputs on Analog Buttons Kingofl337 Control System 5 14-03-2007 11:01
Set Default Digital inputs to Low? How? bad Analog value? Generalx5 Programming 11 04-01-2007 18:57
How do the Analog Inputs work? JBotAlan Electrical 3 07-01-2005 00:11
Analog vs Digital inputs? f22flyboy Programming 8 08-11-2002 22:18
