Go to Post I saw a big opening in the bees section and asked if we could sit for this match and was told we were welcome to sit there. Your team made space for about 15 of my team members that came with me. - Debbie [more]
Go Back   Chief Delphi > Competition > Regional Competitions
Unread 09-03-2008, 03:11
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
Walls on Practice Field
Having attended the Arizona regional and being most disappointed to find that the practice field had no walls what so ever I'm curious as to if all practice fields are without walls.
This lack of walls effectively prevented us from testing our hybrid mode as it relied on ultra sonic positioning off of both the inner and outer wall and made even testing a dead reckoning code hard because there was no designated starting wall.
I realize that regional planning committees have a great deal on their hands, but is a real practice field to much to ask for?
Unread 09-03-2008, 03:24
Guy Davidson Guy Davidson is offline
AKA: formerly sumadin
FRC #0008 (Paly Robotics)
Guy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to behold
Send a message via ICQ to Guy Davidson Send a message via AIM to Guy Davidson Send a message via MSN to Guy Davidson
Re: Walls on Practice Field
In effect, you're asking the comittee to provide an entire second field, compared to what is needed right now, which is an overpass (which many teams already have built) and some carpet.
I don't know enough to tell you if most regionals can afford another field and the volunteer time to set it up and tear it down. However, I do know that many regionals don't even have the space of a whole field is a a practice field, making this request less than feasible.
Unread 09-03-2008, 03:31
I agree that the logistics of having a second field are daunting. Why not then allow teams (on a strict sign up basis) to use the competition field for testing after the days matches? As the fields become more and more complicated it becomes more and more important for teams to have a complete field to work with.
Unread 09-03-2008, 03:35
I don't think the field is becoming more and more complicated - I'd argue it's far simpler than the monstrous rack last year, and also simpler than the triple play field.
As for that? I don't know. You'd have to ask the regional committee or GDC, I assume, to get a good answer.
Unread 09-03-2008, 04:15
Boydean's Avatar
Boydean Boydean is offline
The Blue Alliance
Boydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant future
Send a message via AIM to Boydean
I have not competed in FRC before this year so please correct me if I'm wrong.
I would agree that in the physically the fievil) plus the facts that the other side is filled with three old is simpler, but programming wise the field is much harder to navigate. With the turns(the middle wall is ether robots, for all you know know one of them might not have a hybrid and are just sitting there waiting to be hit by a blind robot. With out the green lights the field supplies very little reference to were you are, other than the walls and use of gravity based sensors(but then again they did supply us with the IR).
On that note, I would agree that it can be difficult to set up a second field for practice.
Unread 09-03-2008, 13:10
rachakate's Avatar
rachakate rachakate is offline
Life's Good
AKA: Kate Leipold
FRC #0340 (Greater Rochester Robotics)
rachakate has much to be proud ofrachakate has much to be proud ofrachakate has much to be proud ofrachakate has much to be proud ofrachakate has much to be proud ofrachakate has much to be proud ofrachakate has much to be proud ofrachakate has much to be proud ofrachakate has much to be proud ofrachakate has much to be proud of
Send a message via AIM to rachakate Send a message via Yahoo to rachakate
At FLR we hung white table clothes up for walls. We also taped off the finish line, and the starting locations. I never heard anyone specifically say that it helped a lot, but I did stop hearing complaints.
Unread 09-03-2008, 14:59
XXShadowXX's Avatar
XXShadowXX XXShadowXX is offline
They call me Cody.
no team (None currently :\)
XXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud of
There were no walls at flint, which is the same stuff that will be used in detroit, west michigan, and (other michigan, i stink at spelling and won't try).
Our wall was me and 3 mentors .
Is now an engineer thanks to FIRST.
Unread 09-03-2008, 15:14
At least last year, the practice fields did not come with walls. Barriers were usually created by tables, if at all. So I'd say that for practice fields, it's bring your own wall.
I'm not sure if the competition fields can be opened after practice matches. It should be possible, but I'm not the one to make the decision.
Unread 09-03-2008, 15:15
GaryVoshol's Avatar
Cogito ergo arbitro
Ouch - I wouldn't want to stand in the way of your robot!
(since 2004)
Unread 09-03-2008, 16:21
Kims Robot's Avatar Unsung FIRST Hero
Kims Robot Kims Robot is offline
Onto a New Chapter...
AKA: Kim O'Toole Eckhardt
Kims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond repute
Send a message via AIM to Kims Robot
Kate already mentioned we didnt have walls, but what we actually missed was having a full floorspace, as our robot can autonomously cross 3+ lines, and even once knocked both balls off the overpass, without a full field its hard to test a lot of this, without chopping code up.
My thought to the regional committees would be to talk to all your local teams, if you have the space in your venue, see what they can lend you. We had a full field set up for our preship event, and being made of PVC and metal piping, was transportable... Maybe teams and the planning committees could work closer together to get full setups available at the regionals... it would reduce cost and provide more value IMO.
~kim~
Kimberly O'Toole Eckhardt <3
Principal Systems Engineer & Program Manager
History - Team 176, Team 229, Team 1511, FIRST Volunteer!!
My new FIRST Photography Hobby & Angry Eric's Fan Page
Excellence - is the result of caring more than others think is wise, risking more than others think is safe, dreaming more than others think is practical, and expecting more than others think is possible.
Unread 09-03-2008, 19:54
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Many venues, BAE GSR for example, just does not have the space for a full practice field. BAE GSR only had an overpass and a small carpeted area (about equal to 1/4 of the field) with no proper walls. This made testing any auto-code almost impossible.
Allowing teams, on Thursday after the day's practice matches, onto the game field (scheduled 5 minute runs) might help, but that would have to be coordinated with all the regionals.
___________________
- Tennyson, Ulysses
Unread 09-03-2008, 21:18
rachakate's Avatar
Life's Good
AKA: Kate Leipold
Great idea Kim. I'll forward that along for next year. I think the venue still has the room for a full field in the corner. And for teams not looking to try both lanes, we could have had two teams on the field at once.
Building Practice Field robotrobot2 Technical Discussion 11 24-01-2008 01:54
Practice Field at NJ slickguy2007 Regional Competitions 1 06-03-2005 19:42
Looking for Practice field tong Off-Season Events 1 04-07-2004 17:55
Practice Field at Palmetto? Kel D Regional Competitions 3 28-03-2004 23:47
Practice Field miketwalker Championship Event 3 29-03-2003 22:57
