Go to Post Has anybody seen our programmer? He was last sighted walking southbound in the rain, his laptop tucked under his arm, grumbling to himself. - Taylor [more]
Unread 09-03-2008, 10:50
FRC4ME FRC4ME is offline
FRC #0339
FRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant future
Victor Brake/Coast Default
Our team has always run the Victors without the brake/coast jumper installed due to a line in the pre-2005 IFI manual that says "If no jumper is installed, the speed controller will default to a Brake condition."
We just discovered, however, that that line was removed from the manual after a 2005 revision. Can anyone confirm that the Victors still default to brake if no jumper is installed?
Unread 09-03-2008, 11:53
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: Victor Brake/Coast Default
I cannot confirm if they changed anything, but if the user manual says to do it, I would do it.
Last year, and the year before, I just removed the jumpers because that is what I remembered doing in 2005, but this year while reading the user manual, I found that it said specifically to not run without a jumper installed, so I think we left the jumpers on, and set to brake.
If I remember correctly, in 2005, if you would put the jumper on brake, it would only brake it in one direction, if you removed it, it would brake it in the other direction, but I cannot confirm this.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 09-03-2008, 12:11
Jetweb Jetweb is offline
is good at making robots find walls
AKA: Jonathan
FRC #0179 (Children of the Swamp!!!)
Jetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to all
according to the picture at the top it looks like open (no jumper) is coast mode.
http://www.ifirobotics.com/docs/ifi-...al-9-25-06.pdf
Unread 09-03-2008, 12:21
FRC #0339
We are going to go ahead and install the jumpers anyway since the manual now says to always install them, but we are wondering if it is going to make any difference.
Why do you say that? It looks to me like the picture is simply showing the jumper in the coast position.
Unread 09-03-2008, 12:47
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Here are the lines to look at from the Victor manual:
Brake / Coast Guidelines:
1. Always install jumper to prevent loss. If you lose
the jumper, a standard computer jumper will work.
2. The Coast condition (Jumper on Inner two Pins) sets
the output to an open circuit during neutral.
3. The Brake condition (Jumper on Outer two pins)
sets the output to a short across the motor leads
during neutral.
If the jumper is missing, that is an open condition which means "Coast"
Note #1. It just says to install the jumper to "prevent loss" There is no functional reason to do so if you desire a coast configuration.
Unread 09-03-2008, 13:01
AKA: Jonathan
If you look closely there is a + on the only visible brake/coast pin. and I remember that the center is signal and that makes the other pin ground so in coast mode the circuit open and brake mode is closed. So no jumper = coast mode.
My team is actually controlling the brake coast with a Digital IO cable so we have played with it a little.
Unread 09-03-2008, 19:55
Dan et al,
The manual goes on to say...
"The speed controller checks the status of the jumper
approximately 60 times per second. This allows the user
to change from brake to coast during operation."
Unread 31-03-2008, 13:40
copperhead47's Avatar
copperhead47 copperhead47 is offline
AKA: Grant "gunner" T.
FRC #1647 (Lenape Regional Iron Devils)
Team Role: Electrical
copperhead47 is an unknown quantity at this point
Send a message via AIM to copperhead47
in past years the victors didnt have any marking on the brake coast jumpers but the newer ones do. now, i dont know if thats just the product of a new design revision or they did that on the reasoning that "b" would be brake and "c" would be coast so that you knew which ones is which. so for safety i would go by the markings and leave the jumper in whichever one you want. If the victor doesnt have b or c on it? compare it with a vic. that does. thats all i got- im out
Using Digital Output to control Brake/Coast on Victor Neurovirus Programming 11 31-01-2008 23:33
Brake / Coast switching for Victors nreyesciena Control System 2 28-01-2008 13:17
Victor 884 Brake/Coast Issues sciguy125 Control System 23 23-01-2005 14:46
Speed Controller brake/coast setting steven114 Electrical 21 03-03-2004 13:05
Brake/Coast Jumper archiver 2001 3 24-06-2002 01:04
