Go to Post TL;DR: The robot battery (and your car battery) aren't going to electrocute you unless you stab a positive and negative wire from them into your heart. In which case you have plenty of other problems besides. - Kevin Sevcik [more]
Unread 09-03-2008, 12:19
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Re: 1726 Electric Problem
Also, check your crimps on your battery connector. This is probably the most mechanically stressed connection in most people's machines as it is the only one which gets moved every time a battery is changed. Also, it is the highest electrical load connection in your robot. I suggest checking both your ground and positive terminals going into your distribuition and breaker blocks respectively.
Our positive terminal came off of our robot at the end of our first semifinal match in Chicago... thankfully we noticed it when it fell out of the robot while changing the battery!
Then again, we also had the eh.. small problem... of one of our ultrasonic sensors catching fire... but that's another story entirely.
Hope you find your problem! If all else fails, tug on wires and see what pulls out/moves easily.
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Overall electric help Aces Electrical 6 12-01-2007 20:16
Electric Bicycle RudimentaryPeni Chit-Chat 6 05-10-2006 14:24
Electric Solenoids BerserkerSpyke Rules/Strategy 3 01-02-2006 17:36
Electric Solenoid ThomasP Motors 5 10-01-2006 16:47
Gas or Electric?? Clark Gilbert Chit-Chat 14 11-08-2001 12:16
