Go to Post Ah, free slave labor. One of the many benefits of being a mentor - Ari423 [more]
Unread 09-03-2008, 15:04
XXShadowXX's Avatar
XXShadowXX XXShadowXX is offline
They call me Cody.
no team (None currently :\)
XXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud of
Re: Knocking the ball off: A viable and important strategy lost in the whims...
Knocking track balls off in hybrid is very important. Which is way we are re-writing to include this. With a track knocked off and you turn the corner, then you get 16 points, one bot in 15 seconds, not bad. Especially notstopping as you remove the trackball (12 points) if you can cross the line under the track ball.
also a question, if you remove oppent's trackballs in hybrid then do they get points.
Is now an engineer thanks to FIRST.
Knocking Down Ringers Strategy Matt21q Rules/Strategy 14 29-01-2007 13:36
What's really important after the competitons are all said and done for the year.. Elgin Clock Math and Science 2 23-03-2005 11:22
pic: Got the ball and the goal CD47-Bot Robot Showcase 3 12-07-2004 22:08
Knocking out Doubler Ball mightywombat Rules/Strategy 47 23-02-2004 15:18
Knocking over Ball via Tee tminard Rules/Strategy 2 07-02-2004 11:35
