Go to Post Admiration is universal, it does not exclude those who have achieved past success. - hg273 [more]
Unread 09-03-2008, 19:21
Aren_Hill's Avatar
Build Nifty Things
Re: Linear Shooters - How did you do it?
We use 1 fischer price motor to retract our shooter and we use that same motor to fire it through an interesting linkage you'd have to see in person, its kind of hard to explain. One of the most amazing aspects i think of our shooter is that it can be fully reloaded ready to shoot again in less than 3 seconds, and we can shoot far
A guy who likes robots.
Unread 09-03-2008, 20:46
DrewB's Avatar
DrewB DrewB is offline
That Guy in the Duck Tape Suit
FRC #2354 (Wheelie Bots)
DrewB is an unknown quantity at this point
Send a message via MSN to DrewB
Our shooter is pneumatic, we use a two cylinders to retract the mechanism building force upon two large springs. When the mechanism reaches a certain point a latch holds the force as we release the pressure that was stored in the cylinders. Then using a pneumatic latch release we can release the force and propel the ball through the air.
Unread 09-03-2008, 22:47
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
95 has a rigging of several pneumatic pistons. I believe there are 7. I took a closer look at their machine at GSR but I can't remember how many pistons they used.
That robot could launch the ball a good 8 feet into the air.
thebluealliance.net has some good videos of their launches.
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 10-03-2008, 08:31
jskene jskene is offline
None #0612
jskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to behold
We use a direct thrust linear shooter, with 2 24" x 2" pistons. We directly connect two Clippard storage tanks to each cylinder through 1/4" SMC solenoid valves. By storing the air downstream of the pressure regulator and using short, direct connection with 1/4" fittings, as opposed to the more common 1/8" fittings, we get much higher air flow.
The arms in the photo on the left below are shown in their stowed position, at the start of the game. When the elevator rises up, they swing out to the front of the robot. The 4 gray wheels then pull the ball in, the elevator raises the ball to the desired height, the pistons rotate out under the ball, and we shoot, below right. This design allows us to shoot on the fly.
Jerry Skene, mentor OOO OOO 2010 - Chairman's Award- DC OOOOOOOOOOOOOOOOOOOOOOOOOOO
Chantilly Academy, Team 612 - 2009 - Engineering Inspiration Award; Finalist - New Jersey
-----------------------------------2008 - Chairman's Award; Kleiner Perkins Award -Buckeye ---| ---Team Spirit Award - NASA/VCU
-----------------------------------2007 - Chairman's Award - NASA/VCU ---| ---Finalist; Kleiner Perkins Award - Chesapeake
-----------------------------------2006 - Chairman's Award - Chesapeake ---| --- Engineering Inspiration Award - NASA/VCU --
Unread 10-03-2008, 17:20
dpc131's Avatar
dpc131 dpc131 is offline
AKA: Dan
FRC #0836 (Robobees)
dpc131 is a jewel in the roughdpc131 is a jewel in the roughdpc131 is a jewel in the rough
Sounds like we have a very similiar design. We are using 4 springs instead of 2, but other than that it sounds identical. Any pics?
Dan Cell
Systems Eng. Mentor
Team 836 - The Robobee's
How did you learn to program? vivek16 Programming 20 04-03-2007 18:15
How did you control your Robot? 1? 2? Wheel? How? ChrisCook Control System 9 17-05-2005 21:41
How did you do your axles Justin1636 Technical Discussion 11 04-05-2005 18:04
How did you learn how to use Inventor? Greg McCoy Inventor 26 24-05-2003 01:55
How did you guys manage it? archiver 1999 1 23-06-2002 21:56
