Go to Post As guests in the city, we should make an effort to do some fundraising for the folks affected by the storm. Any ideas out there? - Jon236 [more]
Go Back   Chief Delphi > Competition > Regional Competitions
Unread 09-03-2008, 21:39
in between teams
AKA: Luke Van Oort
Re: Important 80 inches!!!
Originally Posted by Laaba 80 View Post
So what happens if a penalty is called on your team for extending past 80in? I see where you are coming from, however this is one thing that the refs wouldnt have needed to worry about. It would be alot easier for the inspection crew to measure the rubuts full length than try to measure robot speed.
Joey
It depends on the circumstance. Our robot has a two-jointed arm, and if the wrist and shoulder are both straight out, we violate the rule. In proper operation, the software allows two shoulder states, up and down, which have their exact position chosen to make it impossible for us to go over 80" no matter what the position of the wrist is*. The software also controls the transition between these two states, so the wrist can't extend too far then either. For us to violate the 80" rule it we would have to either have a code error (which would be very obvious and result in us hitting the e-stop immediately given how dangerous our arm can be), or fall over. There isn't anything we can do about preventing the falling over problem, which affects any robot that uses an arm or forklift to hurdle. Anyway, my point is that in either case it would be very obvious that we had exceeded the limit and would go along with the ref's decision.
*Those that saw our robot at VCU will note that this is not how our arm acted. We were having mysterious bugs with our PID loop for the shoulder joint, which forced us to go over to fully manual control for all of our matches (we finally got it working while eliminations were being played). So, at VCU, we could have violated the 80" rule if our arm driver had messed up. If that had happened, we would again not protest the ref's decision because they have a much better view of our robot's profile than we do from the player's station.
Team 1219: 2009 - Mentor
Way over 80 inches!!! iPilipino General Forum 10 17-02-2008 12:36
80 inches Pneumaticsman Rules/Strategy 6 20-01-2008 00:01
4 inches vs. 1 foot Golfer241 Technical Discussion 24 15-02-2007 00:42
pic: 2004 Robot+ 2 Ringers= 12 inches 358_4_Life Extra Discussion 5 16-01-2007 08:11
pic: 612 rollin on 6 inches Priyadarshy Extra Discussion 6 12-10-2006 15:46
