Go to Post Some things can only be revealed by time. - ChrisH [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 10-03-2008, 12:05
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Need help, Titanium / Carbon Fiber / Aluminum
More things to remember:
Three important properties of a material are it's modulus of elasticity, it's yeild strength, and it's tensile strength.
The modulus of elasticity is how much stress it takes to deflect a certain amount. Polycarbonate has a very low modulus of elasticity, steel has a high modulus.
Yield strength is how much stress it takes to permanently deform the material. A soft aluminum alloy such as 3003 has a low yield strength, while a hard alloy like 7075 has a high yield strength.
Tensile strength is how much stress it takes to break the material. You'll find that different alloys of the same material (aluminum, for example) will have different ratios of yield strength to tensile strength--that is, the stronger the alloy, the sooner it breaks after first bending.
Do you want your part to be more flexible, or do you just want it to flex further before becoming permanently bent? A material with a lower modulus of elasticity will generally let it flex a lot more before bending, but a harder material with a higher modulus will take a lot more stress before it finally bends.
NEED: carbon fiber/kevlar/composite I-beam Gabe15 General Forum 2 10-01-2008 08:44
Carbon Fiber Jeff K. Technical Discussion 29 19-10-2006 23:05
Carbon fiber edomus General Forum 4 19-02-2004 19:02
Carbon Fiber kbmeister Kit & Additional Hardware 6 07-01-2003 12:24
Carbon fiber? Munchausen Technical Discussion 1 25-01-2002 21:20
