Go to Post I think that everyone should just take a step back and look at the whole picture, FIRST is a family, not an organization full of regions, we all try to help each other, not 'cause it benefits us, but because it's graciously proffesional. - Mike Schroeder [more]
Unread 10-03-2008, 13:50
AKA: Dr. Brooks
no team (WRRF)
Re: Rebuild
There is an important fine point here. You can take a mechanism
home for repair/upgrade, but you may only bring parts (subject to
the 25 pound limit for all of your fabricated parts) back to the event.
The mechanism that you might have repaired/upgraded must be
brought to your next event as parts, and then assembled in the pit
at the event.
Eugene
Originally Posted by Alan Anderson View Post
Besides what is shipped in the robot crate, you may bring only 25 pounds of fabricated robot components and/or mechanisms to a competition. You may not use flames (no welding torches) or create sparks (no grinding wheels) in the pit. You may not work on the robot before the pits open or after they close. You may not remove the robot from the venue. That's about it for restrictions.
Bring as much raw material as you want. Bring all the portable tools you want. Bring blueprints, assembly drawings, jigs, templates, etc. You can rebuild your robot completely if you have enough time.
Unread 10-03-2008, 13:56
Re: Rebuild
It wouldn't be a Midwest Regional without a certain un-named team, rebuilding their robot on Thursday after a post ship, planning session that changes their strategy.
Unread 10-03-2008, 20:03
AdamHeard's Avatar
Lead Mentor
Re: Rebuild
nor would it be a midwest regional if that certain team didn't face 111 sometime in the elims.
As for rebuilding, it's been done before, by lots of teams. Just keep it within rules.
Unread 10-03-2008, 18:37
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Rebuild
at the event.
Eugene
Eugene,
That was the case in years past, but I think the definitions in the rules this year make it pretty clear that you can bring in pre-assembled mechanisms as spare, replacement, or upgrade parts.
Unread 10-03-2008, 19:22
mathking's Avatar
mathking mathking is offline
Coach/Faculty Advisor
AKA: Greg King
FRC #1014 (Dublin Robotics aka "Bad Robots")
mathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond repute
Re: Rebuild
We did this a couple of years ago at the Championships. A near fatal design flaw revealed itself at Buckeye and we had a robot that could do four things poorly and nothing well after a bad impact. So we decided that doing three things well was better. As several people have said, the key is having a good plan. We went over the plan a couple of times to make sure that we had thought of (almost) everything. We made sure we had all the parts we needed. And we had someone in charge of each part of the process. One of the important things was to manage how we would all interact with the robot. When you are all trying to work in the robot at once, you get in each others' way all the time. Good luck.
Thank you Bad Robots for giving me the chance to coach this team.
Rookie All-Star Award: 2003 Buckeye
Engineering Inspiration Award: 2004 Pittsburgh, 2014 Crossroads
Chairman's Award: 2005 Pittsburgh, 2009 Buckeye, 2012 Queen City
Team Spirit Award: 2007 Buckeye, 2015 Queen City
Woodie Flowers Award: 2009 Buckeye
Dean's List Finalists: Phil Aufdencamp (2010), Lindsey Fox (2011), Kyle Torrico (2011), Alix Bernier (2013), Deepthi Thumuluri (2015)
Gracious Professionalism Award: 2013 Buckeye
Innovation in Controls Award: 2015 Pittsburgh
Event Finalists: 2012 CORI, 2016 Buckeye
Unread 10-03-2008, 19:42
AKA: Dr. Brooks
no team (WRRF)
Re: Rebuild
Originally Posted by Kevin Sevcik View Post
Eugene,
"REPLACEMENT PARTS – A COMPONENT or MECHANISM"
I stand corrected...
Unread 10-03-2008, 20:01
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Re: Rebuild
Sure... we did this at BMR in 2006. We shipped a loosely connected bunch of parts that was built into a robot in the first half of thursday.
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 10-03-2008, 20:04
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
Re: Rebuild
I was a part of the Team 4 One-day Wonder experience in the 2006 GTR where our competition robot did not arrive until Friday from the Los Angeles Regional the prior week. We got a tremendous amount of help from many teams there (45, 188, 217, 1310, 1398, and others) to build an entire robot on Thursday and competed with it on Friday. A team that chooses to rebuild their own robot shouldn't expect that kind of support at a regional.
In Atlanta that same year, the Team 4 students decided to rebuild the competition robot and barely managed to get it done. But the robot didn't move at all in the first match and performed poorly until about the fourth match. By that time, the damage was done and Team 4 did not get selected for the elimination round.
So, there's nothing in the rules against rebuilding a robot, but it might be less than a wonderful experience. I'd stick to minor upgrades and giving the drive team more practice opportunities on Thursday. There's an addage in FIRST: "A good driver will beat a better robot".
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Pump Rebuild Kit? BillCloyes Pneumatics 0 19-12-2003 16:25
