Go to Post Don't short change your drivers. They really need drive time. - Joe Johnson [more]
Unread 10-03-2008, 19:31
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
Signalling voltage question
Hey all,
I have somewhat of an interesting question/problem. I am trying to interface a Handspring Visor (a very old PalmOS device) to the dashboard port on the OI. Now, the way I understand it, the OI's port is a standard RS-232 port. That would imply it is signalling at, like, +/- 12 volts, wouldn't it? The port on the Visor demands 3.3v, and I think that's a maximum, not a minimum. Is there an easy way, other than trying to track down a serial dock, to do the hardware interface here? I know which pins are the serial pins on this device, but I don't want to fry it with 12 volts. EDIT: Forgot to mention, I am definitely cracking the device open, so the physical interface is not a problem.
I am developing software for it, and this will be open-source for future teams if I get anywhere with it. It's the perfect dashboard device--small, lightweight, battery lasts *forever* and has audible and visual feedback. And an open SDK to boot.
I just don't know enough about the electrical side. I understand there's a way to drop voltage with diodes/a resistor but I don't understand it fully. Perhaps an experienced EE can help me...
Thanks in advance,
JBot
EDIT2: Ohh! I could just use a MAX232 couldn't I?
Aren't signatures a bit outdated?
Unread 10-03-2008, 20:32
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Re: Signalling voltage question
You are correct; the dashboard port on the RC signals at +/- 12V. It does this by using a little IC known as a MAX232.
The MAX232 is a voltage level translator specifically designed for the RS232 standard. A quick Google search on the chip number will turn up a datasheet.
Use is quite straightforward--after connecting a few required capacitors, connect the RS232 RX pin to the RC dashboard port, and the LVTTL RX pin to your handheld's RX pin.
Best of all, you can request a free sample of the chip in a DIP package from Maxim's website at www.maxim-ic.com!
Hope this helps...
Eldarion
EDIT: As mentioned below, the MAX3233E is definitely a better choice for this application. Having cut my teeth on the venerable MAX232, I tend to use it for everything...
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 10-03-2008, 20:38
The RS-232 specification says valid signals are anywhere from +/- 3 to +/- 12.
I don't believe the Visor does standard RS-232 by itself. It needs external hardware (in a serial cradle or cable) to convert the levels on its connector.
Is there an easy way, other than trying to track down a serial dock, to do the hardware interface here?...EDIT2: Ohh! I could just use a MAX232 couldn't I?
A MAX203 would require fewer external parts. Look here for a relevant project.
Unread 10-03-2008, 20:42
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Almost. But the MAX232 chips need a 5V supply and thus have 5V TTL outputs. Not toooo likely to fry your Visor, but if you're already going to the trouble I think you more likely want something along the lines of the MAX3232E which can operate from a 3.3V supply.
EDIT: In line with Alan's suggestion, there's also the MAX3233E hat doesn't require external caps but still runs off 3.3V
Unread 11-03-2008, 01:15
Steve_Alaniz Steve_Alaniz is offline
FRC #2848 (All Sparks)
Steve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond repute
ONLY if you eliminate the capacitors that are suggested for the chip. They provide a "Charge Pump" that shifts the voltage levels from 0-5V to about -10v to +10v.. then it's just operating as a line driver...not it's main design function. ( Output... oh, you mean the TTL side of the chip. since you have an RX and TX on both sides, you really can't say one side is input and the other output. A little terminology cross talk there.) It's a really nice chip! Not that this really matters because ....
I agree... this would be the way to go. There are internal capacitors that do the voltage boost so you can use the TTL 0 -3.3V and get the RS232 on the output. Too bad you just can't bypass the OI RS232 shift and just go TTL to TTL.
Steve
Unread 11-03-2008, 22:55
JBotAlan's Avatar
AKA: Jacob Rau
FRC #5263
Thanks. I have ordered a sample; I'll see if it works for me when I get it.
JBot
Signalling Methods during Hybrid 114Klutz Programming 6 07-03-2008 15:19
Quick question relating voltage across compacitor Adam Y. Math and Science 2 11-11-2005 19:39
OI Voltage JAH Electrical 7 12-11-2004 20:01
Battery voltage Josh Siegel Programming 5 22-12-2003 10:15
Voltage Byte -> True Voltage Ulibrium Technical Discussion 11 01-03-2002 08:55
