Go to Post I don't care if your robot could eat ours for breakfast - PayneTrain [more]
Unread 11-03-2008, 13:58
yossi56 yossi56 is offline
FRC #0007
yossi56 is an unknown quantity at this point
SRF05 Ultrasonic Range finder
Hi,I try to get value ftom Devantech SRF05 Ultrasonic Range finder
I rear little in PIC18F6520 Datesheet and find some information about Capture Mode and think if it is good for this project.
Someone use this sensor befor (i Used serch..) and can see me The code i c?
I use in mcc18 compiler in mplab
thanks and sorry on my english spelling.
yossi
Unread 11-03-2008, 14:05
Racer26 Racer26 is offline
Re: SRF05 Ultrasonic Range finder
I'm not sure what you're looking for, exactly, but I think you're looking for code to operate a SRF05 rangefinder on a FRC Robot Controller... I'm a bit confused by the PIC18F6520 reference... The FRC Robot Controller (provided by IFI), since 2006 has contained a PIC18F8722, and before that, a PIC18F8520, I think you may be referring to one of these. As for that specific sensor, I believe you need to set up serial communications with it. You can use the TTL serial port on the Robot Controller, and perhaps Kevin Watson's code to start with, but you may need to use a RS232->TTL conversion chip or similar to interface the two.
Unread 11-03-2008, 18:27
MCahoon MCahoon is offline
FRC #3826 (Sequim Robotics Federation)
MCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud ofMCahoon has much to be proud of
There is code at
http://www.chiefdelphi.com/forums/sh...ght=ultrasonic
to generate the trigger pulse and measure the echo pulse which is returned same as the method for using the SRF05.
It is intended to run on the current version of the RC.
Unread 13-03-2008, 16:48
FRC #0007
Thanks its good to my mission
pic: range finder falconmaster Extra Discussion 6 10-02-2008 22:49
Ultrasonic Range Finder nekng Programming 7 30-01-2008 23:00
Ultrasonic range sensors for Vex Robot OneCoolDude Programming 1 01-12-2007 09:22
Using VEX range finder on the full-size FRC CronosPrime1 Programming 3 08-02-2006 23:29
Ultrasonic Range Finder polyBot Control System 15 29-01-2006 12:46
