Go to Post Every single team in FRC has had a rookie season. All those... have stories. Some are sad, some are funny, some are inspiring - but all the teams have stories to be told... Each year is a chapter in the team's history book with stories to be told and shared. - JaneYoung [more]
View Poll Results: Which environment?
MPlab 44 53.66%
EasyC Pro 24 29.27%
Eclipse 14 17.07%
Other 16 19.51%
Multiple Choice Poll. Voters: 82. You may not vote on this poll
Unread 11-03-2008, 15:41
SL8's Avatar
SL8 SL8 is offline
AKA: Jesus
FRC #0647 (Cyber Wolf Corps)
SL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud of
Send a message via Yahoo to SL8
What programming environment do you use?
If other, specify.
I was wondering about your experiences with that environment.
Unread 11-03-2008, 15:50
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Re: What programming environment do you use?
Depends on what I'm working on:
Visual C++ for, uh, C++ projects usually OpenGL type stuff.
Borland JBuilder for Java although they've been bought out and JBuilder has turned into Eclipse which I'm not too comfortable with.
Emacs for Perl when I'm working in a Linux environment. A computer science teacher forced us to use Emacs one semester and it's stuck now. If I'm making small changes to C or C++ code that's already on Linux, then I'll go ahead and use Emacs for that too.
Only time I work with C is for FRC. I tend to poke around with our team's program using MPLAB, but the students use EasyC because they aren't very good with coding yet. I'll try some stuff out using MPLAB and then try and get them to replicate the effort with EasyC.
Unread 11-03-2008, 16:33
proegssilb proegssilb is offline
AKA: David Bliss
FRC #0904 (D^3)
Team Role: Scout
proegssilb is on a distinguished road
I use Eclipse, they use EasyC and Eclipse.
Unread 11-03-2008, 16:37
For FRC, I use MPLab. For other team-related software projects, I often write Tcl programs. I didn't put "Other", because I don't think that Notepad counts as a programming environment. :-)
Unread 11-03-2008, 16:38
lasereyes's Avatar
lasereyes lasereyes is offline
College Student Mentor
AKA: Farzin Fatollahi-Fard
FRC #2551 (Penguin Empire)
lasereyes is an unknown quantity at this point
Send a message via AIM to lasereyes
I am generally know programming concepts (from JavaScript, and other past experiences), but this was the first time I had to use C. Although I would've loved to learn C and use either MPLab or Eclipse, I didn't have the time to learn it in 6 weeks. So I ended up using easyC.
Not that there's anything wrong with easyC. EasyC is a great program for people to become familiar with programming in general. However, I do with I knew enough C to use an actual program (programming isn't supposed to be easy).
FRC #2551 (FTC #646): Penguin Empire
2008 Rookie Team
2008 UC Davis Sacramento Regional Finalists (thanks to 1388, 1072, and 2390)
2008 UC Davis Sacramento Regional Highest Rookie Seed (#2!)
Unread 11-03-2008, 17:39
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
For robotics I use MPLab.
For .net and web programming I use Visual Studio 2008, and Notepad++when I don't want to wait for VS to load.
Eric Haskins KC9JVH
Unread 11-03-2008, 17:42
Hiteak's Avatar
Hiteak Hiteak is offline
Improving the Technology World
AKA: Dan Schneiderman
FRC #3157
Hiteak has a reputation beyond reputeHiteak has a reputation beyond reputeHiteak has a reputation beyond reputeHiteak has a reputation beyond reputeHiteak has a reputation beyond reputeHiteak has a reputation beyond reputeHiteak has a reputation beyond reputeHiteak has a reputation beyond reputeHiteak has a reputation beyond reputeHiteak has a reputation beyond reputeHiteak has a reputation beyond repute
Send a message via AIM to Hiteak
For robotics I use MPLAP, for java programs I use Eclipse, and for Python I use IDLE 2.5
RIT '13
Computer Science House Member
Working towards improving technology policy
Student: Team 1930, 2005-2008
Mentor: Team 2999, 2009
Ruckus: 2006 -2010
Volunteer:
NJR: 2008
FLR: 2009, 2010
Unread 11-03-2008, 18:03
Boydean's Avatar
Boydean Boydean is offline
The Blue Alliance
Boydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant future
Send a message via AIM to Boydean
For FRC MPlab, with EasyC for testing.
For non-FRC on the Mac I use Xcode for C++ and Taco HTML and Smultron for CSS.
On Windtel comp I use Visual studio for everything -HTML. Crimson Editor is the best for HTML and CSS.
Unread 11-03-2008, 18:10
SL8's Avatar
SL8 SL8 is offline
AKA: Jesus
In my first post, I actually considered saying that I consider notepad an environment.
Unread 11-03-2008, 18:20
slavik262's Avatar
slavik262 slavik262 is offline
We do what we must because we can.
AKA: Matt Kline
FRC #0537 (Charger Robotics)
slavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to behold
Send a message via AIM to slavik262
For Robo, I'm using MPLab with WPILib. For fun, Visual Studio 2005 and 2008 (mostly Visual Basic.NET and Visaul C++).
Unread 11-03-2008, 18:48
Cow Bell Solo's Avatar
Cow Bell Solo Cow Bell Solo is offline
No Stolte No
AKA: Chris
FRC #2194 (Fondy Fire)
Cow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the rough
Send a message via AIM to Cow Bell Solo Send a message via MSN to Cow Bell Solo Send a message via Yahoo to Cow Bell Solo
When programming our robot I use MPLab and when programming our team's website(http://www.whitebearlakerobotics.com) I use Notpad or Notebook which ever is available on the computer I am using.
Who let the Blue Smoke Out
Team 2194 Mentor - 2012-Present - http://fondyfire.com
Team 2207 Alumni - http://whitebearlakerobotics.com
Iowa FIRST LEGO League Planning Team Member - 2010-Present - http://www.isek.iastate.edu/fll
FIRST LEGO League volunteer - 2008-Present
2008: MN Regional Quarterfinalists, Website Excellence
2009: MN North Star Quarterfinalists, recognized for safety, Website Excellence
Unread 11-03-2008, 18:54
whitetiger0990's Avatar
whitetiger0990 whitetiger0990 is offline
whitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of light
I count notepad as a programming environment. Not a very good one, but hey, you didn't specify it had to be =p
I personally use Vim, to compile I use Make. (I know it wasn't mentioned, but we use Git for versioning)
print$q=chr(ord($q)+$1)while("7443-0201-8465130105-12-03135-82482113-06-7672-070208-0613-70"=~/(-?\d\d)/g);
Unread 11-03-2008, 19:01
laultima laultima is offline
FRC #1458 (Danvillans)
laultima is on a distinguished road
Send a message via AIM to laultima
Im kinda surprised nobody's mentioned it yet. I quickly got sick of the way MPLab displayed code, and after failing to get Eclpise (which I use for Java) to work, I saw a post by a member of team 610 with a link to CodeBlocks.
http://www.chiefdelphi.com/forums/sh...ad.php?t=62212
All you have to do is copy and paste your mcc18 folder into the folder in the CodeBlocks directory and your good to go. My favorite environment by far.
2007 Davis/Sacramento Regional Winner (100, 997, 1458)
2008 Davis/Sacramento Regional Gracious Professionalism Award Winner
Unread 11-03-2008, 19:10
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
code::blocks ftw!
Unread 11-03-2008, 19:13
SL8's Avatar
SL8 SL8 is offline
AKA: Jesus
Specifically, I went over the default code in MPlab, wrote our program in EasyC, and then wrote the program in MPlab. I pretty much had to teach myself, but the white papers in CD were very helpful in getting me started.
I like MPlab generally speaking though.
I would like to mention these three, one on pid loops, the other two on applied programming.
http://www.chiefdelphi.com/media/papers/1904
http://www.chiefdelphi.com/media/papers/1740
What programming tool does your team use? ham90mack Programming 15 13-10-2007 15:52
What environment will you use? Astronouth7303 Programming 14 09-01-2007 14:58
What programming environment did you use? StevenB Programming 10 18-03-2006 09:32
What kind of computer do you use for programming? Rohan_DHS Programming 21 05-01-2006 11:52
