Go to Post If anything, I believe Battle Bots is in the best interest of FIRST. Battlebots helps to create an interest in robotics, and FIRST gives us the opportunity to participate in a robotics program. - Adare180 [more]
Unread 11-03-2008, 17:42
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
A few basic EasyC Pro questions
I have been assigned to take the lead on programming our robot. No one else on my team has programmed before, and I only have very limited experience with EasyC V2 For Vex. I have a few questions about how to program our FRC bot with EasyC pro, as it appears very much geared towards VEX
-Do functions such as 2 motor arcade work with FRC?
-How do I add more than 2 reciever ports (four joysticks) (or is it all one port with a bunch of channels?)
-Same with PWMs, relays.
-Do I need anything special in the initialize program?
-Will the online window work with FRC?
-I assume that the Vex USB converter will also work with FRC, am I correct?
Please correct any blatant misconceptions I may appear to have through this post, as I am very much a mechanical engineer at heart
Unread 11-03-2008, 17:59
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Re: A few basic EasyC Pro questions
First you need to set EasyC to FRC mode. You can do this in options>Robot Controller Setup.
Many of the functions will change after you change controller types. Explore the environment after you change the controller.
I have never tried the online windows, so I don't know.
The converter will work fine.
EDIT: Just to be clear, if a function appear while in FRC mode, it will work.
Eric Haskins KC9JVH
Unread 11-03-2008, 18:00
Joe G.'s Avatar
AKA: Josepher
Thank you very much, I had a feeling I was missing a "switch to FRC mode" button.
Unread 11-03-2008, 18:49
Joe G.'s Avatar
AKA: Josepher
One more question: How would I control a relay using a joystick? I want it so that, when the joystick is pushed 50% in either direction, the relay turns on accordingly, but I cannot find a direct way to operate a relay with a joystick.
Unread 11-03-2008, 19:09
AKA: Eric Haskins
#include "Main.h"
void OperatorControl ( void )
      unsigned char temp;
      temp = GetOIAInput ( 1 , 1 ) ;
      if ( temp > 192 )
            SetRelay ( 1 , 1 , 0 ) ;
      else if (  temp < 64 )
            SetRelay ( 1 , 0 , 1 ) ;
      else
            SetRelay ( 1 , 0 , 0 ) ;
Eric Haskins KC9JVH
Unread 11-03-2008, 21:18
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Yes, there is 2 motor arcade, 4 motor arcade, and same with tank drive. Simply set your joystick ports and axis, and your PWM outputs (and maybe inverts if your drive isn't set up like in the picture.)
When you go to use a function block that uses joysticks, you set the joystick port, and then the axis/button (depending on analog or digital)
All PWM and relays are accessible.
I like to set my driver motors to 127, initialize my camera, etc. Nothing is required here.
Yep, the terminal window is the same.
Yep, USB to serial is USB to serial.
You can directly operate a relay using BUTTONS on the joystick, using the OI to Relay command under the "RC Control" set. If you want it so that it works on the joystick axis, Eric's code is great.
[/quote]
Math in EasyC pro TonyP Programming 1 04-02-2008 09:57
EasyC Pro basic help in the English Language (You get me...) TERTOLA Programming 3 02-02-2008 09:44
MS Vista/EasyC & EasyC Pro rswsmay Programming 1 25-04-2007 10:47
Please post any new questions in the easyC PRO Forum Kingofl337 Programming 0 16-01-2007 11:43
