Go to Post I guess everyone cant play real defense, like actually pushing the other robot instead of ramming it with the intent to destroy. - Dillon Compton [more]
Unread 08-02-2008, 15:58
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
The poor serial port less laptop owners with a ExpressCard Slot
Just to hook everyone up, I made a great find reticently.
If you have a new laptop with only a expresscard slot Startech makes
a great serial port adapter. It has a real UART not a prolific PL2303 usb-to-serial chip.
It can program the 2006-08 controller in about 20 second flat.
Here is the link : http://www.newegg.com/Product/Produc...06&Tpk=ec1s950
Unread 08-02-2008, 16:42
Re: The poor serial port less laptop owners with a ExpressCard Slot
Thanks for the info. Last year I had looked for one that was more then just a usb serial converter but didn't find it.
Unread 08-02-2008, 16:43
A warning to anyone who sees this and decides it's just what they need: "ExpressCard" is not the same thing as "PC Card" (which used to be called "PCMCIA Card").
Unread 12-02-2008, 23:59
I ordered mine from Amazon and got it today. It downloaded at least as fast as our laptop with a real serial port, if not faster.
There are several good PCMCIA cards, but this is the first ExpressCard that I've seen that works well.
Unread 02-03-2008, 07:59
kiettyyyy's Avatar
kiettyyyy kiettyyyy is offline
FRC #1538 (The Holy Cows)
kiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond repute
Send a message via AIM to kiettyyyy
For those who have PCMCIA card slots, try using a Siig PCMCIA 1 port serial card, loads code in about 20 seconds as well. (Much faster than the prolific usb adapters)
Unread 02-03-2008, 09:45
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
As far as I'm concerned the Prolific is basically junk. The most inexpensive way to go is with the usb-serial cable with the FTDI chipset, previously covered here:
http://www.chiefdelphi.com/forums/sh...70&postcount=4
Ed Barker
Unread 07-03-2008, 08:39
ayeckley's Avatar
ayeckley ayeckley is offline
AKA: Alex Yeckley
FRC #2252 (Mavericks)
ayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond repute
I found that the two-port version (EC2S950) was the same price, so I chose to go that route. It arrived the other day, and I can report the same results as the other folks: downloads are quicker and more reliable. The only drawbacks I see are mechanical. It seems like the connector between the breakout harness and the card is pretty fragile, and pre-disposed to breakage in the near future. I wish there was some easy way to strain relieve it, but short of mounting the laptop on a plywood panel I don't see any obvious solution. I'll be packing the old USB->RS232 adapter just in case.
Unread 10-03-2008, 11:37
Kingofl337's Avatar
AKA: Adam
I used hot glue to strain relief mine.
Unread 11-03-2008, 22:25
chaoticprout's Avatar
chaoticprout chaoticprout is offline
can't wait for next years VRC
AKA: Michael Montazeri
FRC #1138 (Eagle Engineering)
chaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant future
Send a message via AIM to chaoticprout Send a message via MSN to chaoticprout
Can anyone confirm if this works with a MacBook Pro running Boot Camp? Thanks.
2009 Los Angeles Regional - Chairman's Award
2009 Granite State Regional - Engineering Inspiration Award
2007 Los Angeles Regional - Engineering Inspiration Award
2006 Southern California Regional - Regional Champions
Dell laptop serial port notquitehere188 Programming 18 26-10-2006 22:32
TTL port to a serial port on a demo board ImmortalAres Programming 16 09-07-2005 23:44
ifi loader with no serial port Jared Stofflett Programming 4 23-02-2004 22:50
Problem with communicating with STAMP through serial port Skabana159 Technical Discussion 2 06-02-2003 21:10
My poor little laptop. evulish Chit-Chat 8 06-01-2003 10:29
