Go to Post Ice cream is an iterative process. - JVN [more]
Unread 11-03-2008, 22:33
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
HM55B Digital Compass - How do I program the controller to read it?
Here's the story:
It's Sunday before the ship date, and I'm out in the shop trying to get our gear tooth sensors to work, yet the robot had a tendency to veer left and attempt to crash into the virtual lane divider which composed of some tables. I'm very certain the code for the gear tooth sensors work, but one side drags a little more due to some meshing issues in the gears. I'm sure that both gear tooth sensors work, and these are not those provided in the kit.
So to sum that up, 2 days before ship, and autonomous doesn't work at all.
In week 2, I did some research on digital compasses, and found the Parallax HM55B. So after waiting 4 more weeks, I decided to buy it and try it out. Well... it finally came in last week, and I took it home and played with it on a BOE-bot, and it worked great. Very accurate, and I was able to drive the BOE-bot down our 20' hall way in my house without it getting off course at all. Of course, the BOE-bot uses PBASIC, and our IFI controller is C. I did some research around the internet for source code for the HM55B, and was able to come up with a few sources, but I do not understand how they work or how to implement them into our system.
Right now I have Kevin's 3.0 code installed on our controller. The compass works through the TTTL port on our controller. I also believe I understand how to wire the compass in... I just need help on the programming side. I'm a 1st year programmer, and have never been introduced into serial communications or how Kevin's code can be used to communicate with the compass.
Any help is greatly appreciated!
Thanks,
RyanN
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Interfacing a digital compass with the RC Kelly Electrical 14 27-09-2007 19:01
Where can I get a digital compass sensor? EHaskins Technical Discussion 6 26-09-2007 18:33
How Can I Program The FRC Robot Controller To Display My Team Number jesusescobar Programming 5 22-01-2007 10:29
Problem with the program downloaded to the controller itsme Programming 9 14-01-2007 12:12
I2C Digital Compass Programming CyberWolf_22 Programming 7 03-01-2005 00:20
