Go to Post Maybe my brain fog factor has expanded after wading through 1114's competition data sheet, so I cannot see the forest for the trees. - Bill_B [more]
Unread 12-03-2008, 00:32
willson.thomas willson.thomas is offline
FRC #1595
willson.thomas is just really nicewillson.thomas is just really nicewillson.thomas is just really nicewillson.thomas is just really nicewillson.thomas is just really nice
Inverting the direction of a Motor
I know this has probably been answered several times elsewhere in the forums, but I can't for the life of me find where.
I am trying to reverse a motor in software. I have two motors connected to a single axle and want to reverse one of them. I want to use the y axis of joystick no. 2.
I realize that the same thing could be accomplished by reversing the + and - wires on one of the motors but IMHO it is better to do this in the code.
Thanks,
Tom
Unread 12-03-2008, 00:40
GRS GRS is offline
FRC #1764
GRS is an unknown quantity at this point
Re: Inverting the direction of a Motor
pwm01 = 255 - pwm01
Unread 12-03-2008, 00:43
FRC #1595
Thank you very much. Knew it should be pretty simple to do.
Unread 12-03-2008, 00:47
GRS GRS is offline
FRC #1764
No problem =)
Unread 12-03-2008, 01:16
AKA: Dr. Brooks
no team (WRRF)
An error here and you could release the magic smoke...
Eugene
Unread 12-03-2008, 11:06
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Thanks,
Tom
These might seem unrelated, but be sure to calibrate your speed controllers when you do this.
The reason is, the Victors don't seem to behave exactly the same backwards and forwards out of the box. We've noticed that setting a PWM to 178 and 78 don't produce close to the same speeds in opposite directions... until you calibrate the Victor.
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 12-03-2008, 11:09
PHP Code:
pwm01 p2_y;
pwm02 = ~p2_y
This flips all of the bits, so realistically it does the same as (255-p2_y).
Unread 12-03-2008, 11:27
Originally Posted by GRS View Post
pwm01 = 255 - pwm01
That should be 254, not 255. The valid range of pwm values is 0-254, and the "neutral" value is 127.
Originally Posted by Tom Bottiglieri View Post
PHP Code:
pwm01 p2_y;
pwm02 = ~p2_y
This flips all of the bits, so realistically it does the same as (255-pwm01).
True, but that's not the desired function.
Your example numbers aren't quite right. 178 is neutral plus 51, and 78 is neutral minus 49.
But you're right about the problem -- the Victor factory calibration is a little off from the IFI pwm outputs, with its actual neutral point at more like 132. That makes your forward value at plus 46, and your reverse value at minus 54...until you calibrate the Victor.
Unread 12-03-2008, 12:05
How is it not? The problem seemed to be very clear. There are 2 motors running on a shaft. One needs to run in the opposite direction of the other. They wanted to attack the problem in software.
Unread 12-03-2008, 12:12
Jimmy Cao Jimmy Cao is offline
AKA: Jimmy Cao
Jimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant future
I guess it's already been posted, but the following should also work.
(all words in all caps are alliases, as I do not actually know the names of all the values)
PWM_LEFT_MOTOR = STICK_FOUR_X;
PWM_RIGHT_MOTOR = 254 - STICK_FOUR_X;
Jimmy Cao
Team 469 2006-2010 Student/Alumni
Team 830 2011-2012 Mentor
Unread 12-03-2008, 12:19
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
I think switching the wires is the best way to go IMO, just because you don't have to worry so much about calibrating, and any wrong software will do some damage to the motors for sure.... but everything up there seems good lol I would just pwm01 = 254 - pwm01 like was said previous, if you really have a problem switching wires
Unread 12-03-2008, 12:38
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Hmm, nevermind, it appears the Victor Calibration procedures are in the IFI manuals.
GitHub
Unread 12-03-2008, 13:17
AKA: Mr. Lim
It's force of habit. We do all our logic on signed chars by subtracting 128 from the unsigned chars. It makes us off by 1 here and there, but we don't risk over or underflowing on endpoints.
Slightly off-topic, since the new controllers were introduced in 2004, I haven't had an issue with the full 0-255 range on PWM outputs. 255 seems to be a valid value, has anyone had any issues?
I haven't hit 255 on the OI analog inputs though.
Unread 12-03-2008, 13:22
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
*sigh* that's what i love about H-Bridges, no confusing 0 to 255 just 0's and 1's
Unread 12-03-2008, 13:26
Any 255 set in the user code is converted by the Master to a 254 before it goes anywhere. So using 255 doesn't cause any harm, but it really becomes a 254 as soon as you hand it off via Putdata().
You'll never see an OI value of 255 arrive at your user code, no matter how hard you try.
CIM Motor Bias Direction jonboy Motors 1 28-01-2008 07:58
Ideas to move in the direction of making FIRST competitions 'fair' KenWittlief General Forum 93 07-11-2006 23:19
Conserving Energy: Stepping in the Right Direction? thegathering Chit-Chat 5 14-09-2006 14:49
Optimal Direction of the Drill and Chips mzitz2k Motors 17 06-02-2004 16:54
Motor Spin Direction archiver 2000 6 23-06-2002 23:43
