Go to Post Regardless on how you feel about any team--respect should be paramount. - MeGuttieri [more]
Unread 12-03-2008, 13:04
scottanderson's Avatar
scottanderson scottanderson is offline
AKA: Scott Anderson
FRC #2608 (MiGHT)
scottanderson is an unknown quantity at this point
Adding match-settable switches
I don't see anything in the rules to prevent this, but I'll ask here just to make sure:
Can we add user-settable switches as "sensors" to allow configuration just before the match when the robot is powered up on the track? Like an on-off switch or the like to do some quick pre-match settings based on current conditions.
Regards,
Scott Anderson
Team 2608 MiGHT Mentor
Unread 12-03-2008, 13:06
BornaE's Avatar
BornaE BornaE is offline
FRC #0842 (Formerly 39)
BornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant future
Re: Adding match-settable switches
Yes, that is completely legal.
I have seen many teams using multiple switches to select their autonomous mode or etc. at the beginning of each match
-Borna Emami
Team 0x27
Unread 12-03-2008, 13:09
Jeff Rodriguez Jeff Rodriguez is offline
Too young to be an 'old guy'
FRC #0155 (Technonuts)
Jeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond repute
Send a message via AIM to Jeff Rodriguez Send a message via Yahoo to Jeff Rodriguez
We use a BCD switch to change autonomus routines right on the field. It allows us 10 different routines.
A little Google magic will give you an idea how they work and how to hook them up.
173, student: 1999-2002
173, mentor: 2005-2010
155, teacher: 2011-
Unread 12-03-2008, 17:08
bcieslak
Posts: n/a
we use a switch box right at the driver's station connected to an unused joystick port. Then we can read back which routine is active on the OI display by using the user_defined variable. Besides switchs you can also add variable controls using potentiometers etc.....
The inputs are read before the field crew enables the autonomous bit.
Unread 12-03-2008, 17:17
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Yes, this is legit, and has been done by many teams, both on the robot and on the OI. One exception is that the "current conditions" can't be the positions of the trackballs, because per <G20>, you are not allowed to touch the robot or the OI between when the balls are placed and the start of the match.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 12-03-2008, 17:18
The Lucas's Avatar
CaMOElot, it is a silly place
We use 2 rotary switches each connected to joystick axis on an OI unused port. This method has been very successful for us the past few years since we always have a lot of Auto modes (>20) and don't want to waste digital (button) inputs. This year one switch sets the starting lane while the other selects a routine/command set.
Robot Inspector
Unread 12-03-2008, 17:53
AKA: Scott Anderson
FRC #2608 (MiGHT)
Thanks for the input, everyone. Very helpful.
Regards,
Scott Anderson
Unread 12-03-2008, 18:10
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
yes it is legit! we are using a jumper to pick our autonomous codes!! are you using it for auto or for something else?? Cause if it isn't for auto I am curious as to what you are planning
Unread 12-03-2008, 18:28
AKA: Scott Anderson
FRC #2608 (MiGHT)
Mainly as a starting lane selection switch.
Regards,
Scott Anderson
Unread 14-03-2008, 00:44
Cow Bell Solo's Avatar
Cow Bell Solo Cow Bell Solo is offline
No Stolte No
AKA: Chris
FRC #2194 (Fondy Fire)
Cow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the rough
Send a message via AIM to Cow Bell Solo Send a message via MSN to Cow Bell Solo Send a message via Yahoo to Cow Bell Solo
The one thing that I believe you will have to be careful about is that there can only be FOUR operations with control from the IR. So you have 4 types but before the match you flip a switch and it changes all of the operations from button presses. That I believ is illegal.
Who let the Blue Smoke Out
Team 2194 Mentor - 2012-Present - http://fondyfire.com
Team 2207 Alumni - http://whitebearlakerobotics.com
Iowa FIRST LEGO League Planning Team Member - 2010-Present - http://www.isek.iastate.edu/fll
FIRST LEGO League volunteer - 2008-Present
2008: MN Regional Quarterfinalists, Website Excellence
2009: MN North Star Quarterfinalists, recognized for safety, Website Excellence
Unread 14-03-2008, 00:54
Incorrect. There is no limit to how many different auto modes (set by switches, in this case) you can have. You just need one card for every set of four actions that can be performed. Oh, and make sure you have the right card out.
Unread 14-03-2008, 08:20
Racer26 Racer26 is offline
1075 has used various forms of switches for this in the past. Our newest cool toy for auto-mode adjustment is called a Thumbpot (sorry, no part numbers) that I collected when the local battery plant went belly up. Its basically a 2 digit numerical readout where each digit = x amount of resistance. Hooked up to an analog input, and a 0-1024 = 0-99 conversion formula, I can now make up to 100 different automodes selectable on the field in seconds.
Of course, the amount of automodes one might require in this year's game is rather limited, so 100 is a bit overkill. Maybe I'll use it for a top secret function that will prevent traffic jams on the field in hybrid.
Adding Plugins Setsanto 3D Animation and Competition 0 22-12-2007 11:04
Spring pulling before match or while in match?? Bomberofdoom Technical Discussion 3 11-01-2007 08:03
Adding objects Matthew_H 3D Animation and Competition 5 12-02-2004 19:33
Adding my Thanks archiver 2000 0 23-06-2002 22:57
Pre-Match/Post- Match Pit Routine Mark_lyons General Forum 14 31-03-2002 15:19
