Re: Fun Personal Project
That sounds like it'd be a good project, maybe give it an all-independent multi-link suspension, and run the wheels off of one or two two-stroke chainsaw motors in a four-wheel drive system... That would probably be more of a design challenge than a machining one (well, I think it'd be both, but the design would be harder), but it would both sound and look really cool. Cost wouldn't be too bad, I'd think. The steel/aluminum rods for the suspension could be probably be found in a junkyard or manufacturer's scrap bin. If you found a lot of it, you could make the frame out of the same material as the suspension. You could also probably get the chainsaw(s) cheaply off of Craigslist or something similar. I suspect the differentials and control system would be the most expensive parts.
hmmm.... that could very well work.
I honestly didn't know what a differential was, then I looked on howstuffworks thats really interesting, but I'm wondering if its really necessary. I'm not thinking of building something I can personally write in, but drive around... like a little bigger than a FRC bot... would you need a differential for that? |
rail gun?
![]() I did not know what a differential was either. you wouldnt need one if you had tank steer and not skid steer. |
true, and with all things considered, wouldn't a tank drive be better for an all terrain vehicle? So you don't have to keep backing up and all...
oh well, I'll start designing one and depending on how I feel I'll either make it ackermann steering or tank... we'll see ![]() and since i live off campus, it'd be interesting to have me carry home my rail gun on the bus <_< I smell criminal charges all over that... |
Dude, make a longboard. Like, from the ground up. I'm talking designing your own trucks, deck, and so on. It'd be a fun build, and would also be very fun to ride. The trucks would need tight tolerances if you build precision ones (trucks with a spherical bearing), so that would satisfy one of your requirements...
Here's a picture of an aluminum longboard that's already on the market: ![]() Also, feel free to PM me if you have any questions about what goes into one of those boards, as I make similar ones as a hobby/ side job. |
Build a custom NERF gun, completely from scratch. It can be done really low cost (almost entirely from PVC) or a much more precisely/advanced from a variety of other materials. I even know where you can find plans for one if you aren't comfortable making them yourself or wish to try a proven method first.
#7
Build a 15lb Mini Class BattleBot.
#8
Build something that may come in use for yourself. Like the tennis ball thing you mentioned, if you're a tennis player, that will come in handy.
So I would find something that gives you grief everytime you have to do it...then build a robot that does it for you instead. |
#9
A steam engine is always a fascinating machining project. Or a small gasoline engine.
Or, maybe solve a problem with a robot and unintentionally get yourself rich. Like a Roomba - oh, that's already taken. How about a robot that autonomously screws down Trex-like deck boards? A contractor would happily pay $1500 for such an item - dump in a pile of screws, set out the boards, plug it in and walk away... It could be plenty slow. A robot that installs asphalt roof shingles? Autonomously? A snow plowing robot? Even R/C, but from the comfort of a warm, dry house. A fully autonomous dog for the yard? . |
#10
On another note, I have always had the fascination with mowing bots, just how the software would work. |
#11
Thanks for all the replies guys. I'm really excited about working on the all-terrain vehicle since it'd be a good challenge. The long board also seems like a really good idea.
Again, thanks for the suggestions and I'll see if when I'm done with this project I'll work on something else using the tips you guys suggested (of finding something I'm too lazy to do, then building a robot to do it) ![]() |
#12
One last thought: A juggling robot.
| Personal Awards | Kyle Love | Chit-Chat | 19 | 06-05-2005 23:43 |
| Personal robots | John Gutmann | Chit-Chat | 2 | 19-04-2005 20:27 |
| Personal websites | evulish | Chit-Chat | 26 | 01-06-2004 19:43 |
| personal mottos | MOEmaniac | Chit-Chat | 54 | 22-04-2004 23:41 |
| Personal Robot | Alex Forest | Chit-Chat | 1 | 12-12-2002 12:31 |
