Go to Post Remember those two words people. Gracious Professionalism. - Elgin Clock [more]
Unread 12-03-2008, 11:40
eng_tarekwaheed eng_tarekwaheed is offline
eng_tarekwaheed is an unknown quantity at this point
i wanna answer
i wanna to know how can i use the mouse as a feedback position and the contact circuit with it and the hard ware of the circuit
Unread 12-03-2008, 11:51
Graham Donaldson's Avatar
Graham Donaldson Graham Donaldson is offline
AKA: Graham Donaldson
FRC #1676 (The Pascack Pi-oneers)
Graham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant future
Re: i wanna answer
Welcome to CD! I looked at your post list, and saw that all your posts relate to the same topic. Unfortunately, I think the other members of CD will need more information about what you're trying to do in order to help you. If you could post some more specific information, I'm sure that someone will help you out (I'm not electrical or programming, so...)
2008 NJ Regional, 2009 Palmetto Regional: Chairman's Award Winners
2010 NJ Regional Champions (w/ 25 and 3059), 2010 VA Regional Champions (w/ 1086 & 1418)
"Hard work spotlights the character of people: some turn up their sleeves, some turn up their noses, and some don't turn up at all."- Sam Ewing
"Opportunity is missed by most people because it is dressed in overalls and looks like work."- Thomas Edison
Unread 12-03-2008, 12:24
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
Re: i wanna answer
if I can add to what was previously said by saying patience is important when looking for answers... bugging and bugging will not get you answers any faster.
Secondly, why would you want to use a optical mouse for position, as oppose to encoders and gyros? You do realize that it will pretty much have to be touching the ground the whole time to work effectively?
More details on what you are doing is required.
Unread 12-03-2008, 13:11
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
Re: i wanna answer
Are you going to attempt to interface a PS2 mouse with the robot controller? If so, check out this thread:
TTL Serial and PS2 Mouse Interface
Even if you solve the interface issues, you need to consider how mouse resolution (100's of counts per inch) and robot speed (>100 inch/sec) affects your design.
Bottom line: There are much simpler and reliable means to encode your robot's motion.
BTW, your thread title "i wanna answer" reads like a demand. The members of CD will assist almost everyone, but there are more gracious ways to ask for help...and maybe you'll get more responses.
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Unread 12-03-2008, 19:10
Re: i wanna answer
I've used a pair of optical mouse chips to track a robot before. The bot moved about as quickly as some of this year's sprint bots move. The key is changing out the lens so you get a longer focal depth.
It is very possible to do, and I hope that we see them in FRC soon.
However, it is not a project to take on lightly. It took my team of 6 many many hours of banging our heads against the wall.
Unread 12-03-2008, 19:53
Re: i wanna answer
first thanks every one for your replies second i want to make arobot with a mecanum wheel and i want use the mouse to detect the positin of the robot and ididn't use the encoder to avoid the sliping of the wheel
Unread 12-03-2008, 20:38
Caio's Avatar
Caio Caio is offline
Caio has a spectacular aura aboutCaio has a spectacular aura about
Re: i wanna answer
Team 383 made something similar to what you're trying to do, but they used the idea of a ball mouse with an over-sized ball instead of an optical sensor.
Here are some pics if you're interested in maybe doing something like this
http://www.chiefdelphi.com/media/photos/30740
http://www.chiefdelphi.com/media/photos/30741
Caio Tenca
Software Engineer
Founder of Washington SWAT Robotics
Ex-Team Manager, Mech. Leader of Westview Robotics Team 1510
Team 1510 co-founder
Former Team 955 member
Curie lives on in my heart <3
Unread 12-03-2008, 21:43
Re: i wanna answer
Amazingly, those are also referred to as "Trackballs"!
Unread 12-03-2008, 22:59
Caio's Avatar
Re: i wanna answer
seriously? Thats pretty amazing (or coincidental) D:
Caio Tenca
Software Engineer
Unread 14-03-2008, 12:59
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Re: i wanna answer
Well, I don't know about here, but in Brazil those are called billiard balls!
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 14-03-2008, 13:19
Re: i wanna answer
I was referring to the mice that have the ball on top. See: Trackball - Wikipedia
Anyhow, the 383 solution is very cool - especially for robots with omni or mecanum wheels where shaft encoders won't do the job.
Unread 14-03-2008, 15:12
tseres's Avatar
tseres tseres is offline
obsessed with FIRST...
FRC #1565 (Think Tank Tech)
tseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of lighttseres is a glorious beacon of light
Re: i wanna answer
wow, that's a lot easier than encoders on every wheel to decipher the movement data. i should try that next year for a closed-loop linkage system....hmm...
Please Only Answer Questions if you know the Answer! Greg Needel General Forum 30 18-02-2010 12:26
When I grow up I wanna be a... Azure Chit-Chat 23 19-03-2007 08:12
Wanna ask why... Jeremiah Johnson Regional Competitions 22 20-03-2006 11:27
i wanna picture blindguyinanorg CD Forum Support 1 14-02-2004 23:57
ever wanna robomama Chit-Chat 13 10-07-2002 23:37
