Go to Post make your robot so it's not a problem and it won't be a problem - pfreivald [more]
Unread 13-03-2008, 11:11
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer & Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
Re: pic: Three Trackballs?
actually all sides should have panels - outside walls and the divider (basically everything in the center of the field both inside and out have panels... I think...
whats sad is I put this field together and I can't remember for the life of me if there was a side w/o them. A sign of old age :-p and too many field put together.
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
Unread 13-03-2008, 11:20
2003...Oh wait, this is 2008.
Every side has panels. Two have diamond-plate and Lexan panels, four have chain-link panels (this year), and the remaining ones have Lexan on pipes. Even the gates have panels; those are just easily movable by a human.
Unread 13-03-2008, 11:26
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
I could have sworn the field at VCU did not have polycarb on the pipes making up the outside perimeter (at least on the side nearest the stands).
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 13-03-2008, 12:14
Roger Roger is offline
FRC #1153
Rookie Year: 1900
Roger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond repute
Now you guys have got me wondering. A quick search found me this photo which may exhibit my thinking.
The ends of the field where the drivers are have the big lexan panels. The angled corners are the chainlink fence. The center divider are 3 high lexan panels. The low outside sidewalls have lexan, but the outer outside walls are just the metal pipe - no lexan. At least I can't see any. There are no zip-ties holding the panels anyway, like the center divider wall has. I remember at the end of Final matches before the awards they were taking the pipes down on the audience side but no lexan.
I realize there is a need for a protector/divider both at center divider and the long side walls, to keep the trackballs from going all over the place, but the lexan? Keeping robots on own side? Make a rule against it, or add another horizontal pipe. Entangling? Well, the robots do that now on the overpass. I'm sure there was a reason.
Unread 13-03-2008, 12:55
Phyrxes's Avatar
AKA: Dave Button
I always figured it was to prevent manipulators and/or robots from "trying" to go through the center divider, that is the drive base goes under the lowest section of horizontal pipe and your manipulator gets demolished as your entire robot attempts to take a "short cut." It also presents a "solid" object on the "left" to bounce ultrasonic range finders off of.
Dave Button
Wakefield School
The Plains, VA
Unread 13-03-2008, 14:16
Oh, the OUTSIDE ones! I was thinking of the normal field walls. You're right, those don't have any visible. I'd say that's so refs, spectators, and camera people have a clear view with no chance of reflection.
Unread 14-03-2008, 03:39
KarenH's Avatar
KarenH KarenH is offline
Mrs. ChrisH
FRC #0330 (Beach 'Bots)
Team Role: Parent
KarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond repute
You're both correct. The center wall has larger diameter pipes, and the reflective panels are laced in place with substantial cable ties. The look reminds me of leathercraft projects from childhood day camps (moccasins?). The bases for the uprights are covered with carpet pieces. The thing is a bit of a nuisance to assemble, and the cable ties are a nuisance when taking it down, but it looks to me like the greatest nuisance for the field crew is keeping the carpet pieces securely taped down. One robot in San Diego ate one of the carpet pieces, along with the sticky tape, and got "indigestion."
The bases of the outer walls are placed outside the normal side rails of the field. The outer walls have no polycarbonate panels, and have smaller diameter pipes than the inner walls. They also require little or no maintenance during the competition.
From the differing construction, I conclude that the purpose of the center divider is to prevent both trackballs and robots from crossing the center of the field, so it has to be strong enough to withstand lots of rough treatment. But the purpose of the outer fences is merely to keep the trackballs from escaping. So they are neither as robust nor as impermeable as the center divider.
Furthermore, I suspect that the GDC knew very well what the effect of reflective panels would be. After all, they DIDN'T use the stuff on the corner panels.
Karen Husmann
Ex Robo-widow
Unread 14-03-2008, 05:48
Chief Samwize Chief Samwize is offline
AKA: Sam
FRC #0051 (Wings of Fire)
Chief Samwize has much to be proud ofChief Samwize has much to be proud ofChief Samwize has much to be proud ofChief Samwize has much to be proud ofChief Samwize has much to be proud ofChief Samwize has much to be proud ofChief Samwize has much to be proud ofChief Samwize has much to be proud ofChief Samwize has much to be proud of
the reflections on the opposite end of the field are extremely distracting. When driving into the other corner its like going in blind. During a practice match I ran into our own partners, who I didn't see, that were trying to pick up the ball.
Oh well, just another element to the game.
-Sam
Unread 14-03-2008, 09:21
FRC #1153
Rookie Year: 1900
The corner chainlink panels -- wasn't that so the IR can go thru it? But I agree GDC must have seen (or not ) how the center panels act. But I don't think they purposely designed it that way: they probably figured it would be part of the game -- a classic "it's not a bug -- it's a feature!"
I would think if the middle row of panels were removed and another horizontal bar put in would be a better alternate -- do not cross or you will get entangled (or get your parts sliced off!) might be enough of a punishment. I'm thinking of all those robots that tangled up in the overpass.
The sonar can still bounce off the bottom panels, either the inside wall or the outer wall. After all, the outside wall is low anyway.
Last night I tried standing in front of our drivers as they practiced. They got annoyed until I show them those photos. "Oh yeah..." Then we tried the "use the force Luke" approach -- close your eyes and use verbal commands only. Good thing our Robo-Coach has those hand-signals...
Methinks that hat is on too tight EricH ; but I did fear my "the outside outside 'protector' walls (if you follow me)" didn't quite emphasize which I meant.
Unread 14-03-2008, 12:18
ReaperGoat's Avatar
ReaperGoat ReaperGoat is offline
Volunteer
AKA: Ruth Toomey
FRC #0319
ReaperGoat has much to be proud ofReaperGoat has much to be proud ofReaperGoat has much to be proud ofReaperGoat has much to be proud ofReaperGoat has much to be proud ofReaperGoat has much to be proud ofReaperGoat has much to be proud ofReaperGoat has much to be proud of
Send a message via AIM to ReaperGoat
Oh man...that's just...ridiculous
Couldn't they have made the top two out of the chain link fencing they used on the Robo-Coach stations? Or chicken wire, even? There are better ways to keep robots from going through without killing the visibility and putting teams at a disadvantage.
Team 1735 Student (2006), Mentor (2008, 2009)
Team 190 mentor/mascot (2007, 2015, 2016)
Team 319 Mentor (2016-present)
FIRST Volunteer (2009-2016)
Unread 14-03-2008, 14:19
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Could they have? Yes, of course. But then we would probably be complaining about robots getting caught in the fencing/chicken wire instead of visibility. I am sure the GDC considered their options, and decided that (even with its flaws) the Lexan was the best choice for drivers, spectators, and robots.
Jeff Waegelin
Unread 14-03-2008, 17:22
ZInventor's Avatar
ZInventor ZInventor is offline
AKA: Zeno Le Héricy
FRC #2915 (Riverdale Robotics Pandamonium)
ZInventor is just really niceZInventor is just really niceZInventor is just really niceZInventor is just really nice
i can't remember what the stuff's called, but i know that somewhere, i've seen a type of plastic that lets you see through at any angle, and just plain refuses to reflect or refract light.
i've used the stuff at a tech museum (OMSI) where i volunteer, and it's a pain, since the only part of it that you can see are fingerprints on the serface whenever we use it, we have to wash it in windex so that it doesn't look like there are fingerpeints floating in mid air...
i think it's the same stuff they use in stop-motion movies when they have to make something appear to fly
if FIRST had been able to use that stuff (which is just as strong as lexan) instead, itwould be SOOOOOOOOOOOOOO much easier to controll the bot on the lane you currently can't see... lols...
Z
[center]
Unread 14-03-2008, 20:00
GaryVoshol's Avatar
Cogito ergo arbitro
Remember that if you are in your home stretch and you should poke an appendage through the proposed perforated lane divider, you would have generated a 10-point penalty for breaking the plane. The lane divider is directly above the lane marker.
I noticed something in the animation today - there doesn't appear to be any panels in the lane divider. Whether this was an oversight, the initial field design, or just too hard to animate, I wouldn't know.
(since 2004)
pic: Three wheel Redo91 Robot Showcase 8 18-02-2007 15:14
pic: Three colors??? natis Extra Discussion 24 09-11-2006 18:40
pic: My three sons Rich Kressly Robot Showcase 11 22-02-2006 20:46
pic: Three teams one robot Bcahn836 Extra Discussion 9 20-03-2005 18:44
pic:THREE PICS OF NEW ARM!!!! LOOK!!!!!! sgsdragons Robot Showcase 0 13-02-2005 22:37
