Go to Post I hope that kids will stop asking us if we build Battlebots and start asking us if we build Transformers. To that, I will answer with a resounding yes. - Madison [more]
Unread 13-03-2008, 11:24
Jimmy_Team7011 Jimmy_Team7011 is offline
FTC #7011
Jimmy_Team7011 is an unknown quantity at this point
More than 1 autonomos...
It might be such a dumb question, but at the last competition here there were some teams with more than one autonomos programing , and then, they placed jumpers interrupts in the vex rc to change between these programs, is that possible to do , or were they just trying to make us fool?
If there is any way to do it, how?
Unread 13-03-2008, 13:00
whitetiger0990's Avatar
whitetiger0990 whitetiger0990 is offline
whitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of light
Re: More than 1 autonomos...
Yup, we did this last year for FRC and just plain old C, but the logic should be the same, and it's good to understand the logic. We had a lot of digital ports opens, we wired up some pwms to a DIP switch and put it on the digital ports.
Auto_Mode=RC_dip_8;
Auto_Mode=(Auto_Mode << 1) | RC_dip_7;
Auto_Mode=(Auto_Mode << 1) | RC_dip_6;
Auto_Mode=(Auto_Mode << 1) | RC_dip_5;
Auto_Mode=(Auto_Mode << 1) | RC_dip_4;
Auto_Mode=(Auto_Mode << 1) | RC_dip_3;
Auto_Mode=(Auto_Mode << 1) | RC_dip_2;
Auto_Mode=(Auto_Mode << 1) | RC_dip_1;
Basically with 8 switches, you could have 256 possibilities of autonomous modes. The << shifts all the bits in the number left one (basically multiplying the number by 2), and then ORing it with the next switch. In the end you have a char (a number which is 1 byte long, or 8 bits) and 8 switches, each one controlling one of the bits. So by having the switches flipped in different combinations, you have a range from 0 to 255. From that number you can switch statement or just if statements to control what the bot does.
We had no use for that many, but we had the space for it. The number of options you can have is 2 raise to the number of switches used. =)
print$q=chr(ord($q)+$1)while("7443-0201-8465130105-12-03135-82482113-06-7672-070208-0613-70"=~/(-?\d\d)/g);
Unread 13-03-2008, 18:08
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
A real easy way to do it in EasyC is to use some code like this.
If Digital Input == 1
Do stuff
Else If Digital Input == 0
Do other stuff
and so on and so forth
-Dustin Benedict
Unread 16-03-2008, 12:18
FTC #7011
Oh...so its possible.....but i couldnt understand how to do it....could sb explain?
thanks
Unread 16-03-2008, 13:55
DonRotolo's Avatar
Back to humble
FRC #0832
Um, I think they just did.
Let's say that in Autonomous 1 you want the robot to turn left, and Autonomous 2 you want it to turn right.
If (Digital_input_1 = 1) then
     [Code to turn left]
EndIf
If (Digital_input_2 = 1) then
     [Code to turn right]
EndIf
Now, you need to think more about this, because what happens if there are jumpers on both inputs 1 and 2? (someone forgot and put both on). And a lot of IF statements might become impractical if you have 25 different autonomous modes.
Also, make sure there's always one choice for "do nothing".
Don
Unread 16-03-2008, 15:33
SL8's Avatar
SL8 SL8 is offline
AKA: Jesus
FRC #0647 (Cyber Wolf Corps)
SL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud of
Send a message via Yahoo to SL8
Don
THis is especially important cause otherwise youre robot will be stuck doing what ever it was supposed to do last.
more than 4 ir controls? Vanquish Programming 2 12-01-2008 14:52
Robowarriors: More visited than CD! Tim Arnold General Forum 11 26-10-2007 11:54
Software on more than one machine PhatalEphekt Inventor 4 20-01-2004 12:19
More than 2 pneumatic tanks? kangarue23 Pneumatics 10 01-05-2002 12:14
