Go to Post This year should be an unusual object game. You know what an unusual object is? Water. - TheBoulderite [more]
Unread 20-02-2008, 00:44
kE7JLM's Avatar
kE7JLM kE7JLM is offline
KE7JLM `
AKA: John Harris
FRC #0842 (Falcon Robotics)
Team Role: Driver
kE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to all
Send a message via MSN to kE7JLM
IFI Dashboard Sorce Code
Does anyone know if IFI offers source code for the Dashboard program? I am planning on making a Custom GUI (really it is a GI) for our ROV and I thought the source code will save me a lot of time. Although i have been told it is possible I have never seen it done. I greatly appreciate any help someone can give, Thank you.
I will try to do this in VISUAL BASIC
Team 842 Programmer
Pictures at:
http://picasaweb.google.com/KE7JLM
http://picasaweb.google.com/john.h.842
Videos -
http://www.youtube.com/user/KE7JLM
When your not busy with FIRST try NURC
Unread 20-02-2008, 00:54
Re: IFI Dashboard Sorce Code
The source code for the IFI Dashboard is not available. They did document the protocol, so you can write your own. There are also several versions in the whitepaper section here, for which the source is available.
Unread 20-02-2008, 01:17
The Lucas's Avatar
CaMOElot, it is a silly place
You could use Labview
Robot Inspector
Unread 20-02-2008, 09:34
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
Or you can use this:
http://www.chiefdelphi.com/media/papers/1765
You just write a user control that inherits from a base class and implement the callbacks that receive dashboard packets. You can write it in either VB.NET or C#, whichever you prefer. You don't have to parse anything or worry about the serial IO. There are a few nice controls in the 2008 control library. It also has a UDP packet relay that lets you share the data stream with another PC running the dashboard software.
Unread 13-03-2008, 18:19
ND4SPD
Posts: n/a
Thanks for this. I'm trying to create a much more intuitive dashboard for our robot. I'm going to try an recreate this using WPF. Will hopefully update soon!
Problems integrating CMUCAM code and IFI Default Code Windward Programming 2 06-02-2007 16:48
2007 IFI default code question Japper Programming 4 22-01-2007 23:23
IFI Analog Code David Carter Programming 6 12-09-2006 15:35
Labview Dashboard and updated IFI dashboard spec Joe Ross LabView and Data Acquisition 1 04-04-2006 02:04
Code for the Dashboard HuskieRobotics Programming 1 04-03-2004 11:10
